P1000m5 Traveller II
2016 Honda Pioneer 1000-5 Deluxe
I found this stick jammed in the wheel well after yesterday's ride.
Judging by the skid marks, it looks like it could have punched thru the floor. There's an impact mark on the UHMW where it hit. I'd like to think it saved the floor and possibly @ohanacreek legs!
That's what the sound was....
ErikHonda4Life
ErikHonda4Life
15
30
That's how you ride, fast and hard!!
Reactions: joeymt33 and JTW
I was riding the other day with Ohanacreek and one of my friends named Jonathan Payne.
There were several occasions where we were rubbing up against trees in tight turns and Jonathan recommended some UHMW skid plates on the roof.
So, I call these Payne Strips. Super cheap and easy to install. They should keep the factory hardtop from wrinkling anymore than it already has.
A8e4e28733a337fcc54a4faa5078189a
303556bae7d5cfd3b4a7ba74e61a2fe0
Awesome!! I really like that idea! Did you run those into the rops?
Here's a Trail Armor update. I have broke my second piece of UHMW from them. They replaced it free of charge last time. Hopefully they will this time. It breaks at the joint where they've thinned it to overlap.
Cf841b9e9c7bc874d268fcd175d4d5e3
I put a piece of 3/16 aluminum behind each joint on mine but they weren't thinned to overlap. Not sure if it'd help?
Between the 30 inch Roctanes, extra weight from all the accessories, and now the added power, I guess I'll find out just how strong these clutches are. I actually think that 1500 miles with the abuse that I've put on them, they're actually not that bad.
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
I'd actually considered making some mini rock sliders for the top of the rops but I like this much better. Great idea!
Reactions: joeymt33 and sharp
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
I wish there was an autotune available for the AEM fic in my Neon. Wot is easy to tune but partial throttle under boost is a flat out b*tch. Next time we ride together we gotta line em up. Getting my arse handed to me should make up my mind to get one lol.
DGann
DGann
548
1,575
Russellville Alabama
If it can your driving @joeymt33 than it must be good
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
We need some scales. Only one I know of close is at Huntsville dragway.
how did you attach the strings that go over your roof?
I drilled a hole over the roll cage and let the string go straight down and tied it around the roll cage.
Give it a little dot of black RTV and you'll have nothing to worry about.
Reactions: sharp
Similar threads
Hometeam
Replies
Views
2K
Hometeam
