P1000m5 Traveller II
2016 Honda Pioneer 1000-5 Deluxe
X4Dice
X4Dice
87
130
USA
I drilled a hole over the roll cage and let the string go straight down and tied it around the roll cage.
Give it a little dot of black RTV and you'll have nothing to worry about.
Thank you.
Reactions: Eltobgi
I upgraded the phone a couple weeks ago so I decided to use the old one as a multi purpose device. I tied it to the Wetsounds for now. It doesn't seem to affect the sound and the phone is easily accessed.
It will be an inclinometer....
04b5d1c2e0e2a41e21cbf77026c62540
MP3 player always blue toothed to the speaker....
4e0f829571200c807cb86e69c2f0f42f
It will also be a reverse camera/remote control for the rear mounted GoPro.....
D970d207770eebe616f3a737d97b19eb
I'll be able to use the new phone for GPS navy if needed and it can also control the 360 cam. I can't wait to try it all out tomorrow.
Best part about using the phone for those things is I didn't have to buy any thing. I already had the phone and GoPro. I should get a phone mount but at least the zip ties will work for tomorrow's ride.
FREAK'N awesome idea!!!! It time for us to upgrade too!!
Reactions: joeymt33
Oh is that where it happened sharp?
Reactions: sharp
Deer-hunter
Deer-hunter
136
200
Effie,Louisiana
How does one break the inside of the wheel? Glad I had slime in it!
049059bae3ff1f6ce9e51508a892fd65
E6cd8a7290fe9197e6e1dd1107c54814
Wow, I though only my wife could do that. Last year she ran over a metal key way stake used in concrete form work. The stake went through the tire and through the aluminum rim on her edge.
Was it something you ran over that did that or was it from the rocks.
I'm thinking a rock got slung into the back side of the wheel and spun around until it hit the brake caliper. That's the damage pattern I see anyway. Nothing when thru the tire. The dent is pushed in from the outside.
Reactions: JTW and sharp
Similar threads
Hometeam
Replies
Views
2K
Hometeam
