P1000 True Height 32” ITP Blackwaters?
Bayouownbeer
Bayouownbeer
797
1,120
Chauvin LA
Anyone running 32” blackwaters? I know the 28” and 30” run small by 1”-1.5”. I have the 28’s and thy measure 27”. I’ve seen posted that 30’s measure out at 28.5-29”. I’m wondering what the 32” measure out with 9-10 psi.
208,728
My Black Water 30's run 28.75 at 6 PSI. You ride the rocks much?
Reactions: Bayouownbeer
Bayouownbeer
Bayouownbeer
797
1,120
Chauvin LA
What kind of pressure do you run in the rocks?
Around 9 I’m scared to knock one off the bead. You have any issues with 6 psi? With 9 I’ve seen my front tires get about 2” from the rim climbing rocks.
208,728
I'm running outside rim locks and my side walls seem very stiff and haven't been anywhere close to 2 inches off the rim, do they make different Black Waters? All mine do a 8 PSI is spin on the rocks??????
Bayouownbeer
Bayouownbeer
797
1,120
Chauvin LA
There is only one Blackwater. The sidewalls are stiff. I don’t have Beadlocks. I’m taking about like when you like when there is a lot of weight in one of the front tires on the edge of a rock I’ve seen that tire depress down close to the rim. Not to wear it will pop off the bead. But in cornering and such I’m worrried about them coming off the rim. I don’t do extensive rock crawling so really haven’t had a problem with
Traction
208,728
There is only one Blackwater. The sidewalls are stiff. I don’t have Beadlocks. I’m taking about like when you like when there is a lot of weight in one of the front tires on the edge of a rock I’ve seen that tire depress down close to the rim. Not to wear it will pop off the bead. But in Corning and such I’m worrried about them coming off the rim. I don’t do extensive rock crawling so really haven’t had a problem with
Traction
I dropped mine to 6 PSI, well see in the rocks, one thing I noticed even at 8 PSI they got a grip on the logs better. I've got a set of Moto Hammers that have great grip in the rocks, but they wear quickly and don't do very well in muddy conditions. I think I will like the Black Water's, just have to figure it out. PSI.
GlockMeister
GlockMeister
The Bearded Wonder
7,606
35,593
Greenville, Mo
Traction
What is in Corning to ride? Im omly an hour north
500
589
932
I had them on a Teryx. They were around 31.5" if I remember correctly. They are TALL. Awesome tire.
56380
