True to size tires?
I'll measure my Evos and get back to you in a couple days when I get home. I actually haven't ever paid attention to that. The size is 28-11-14. They may be off that a little bit. Do you want over all size including lugs? I only have 100 miles or so, so they should be close enough to new.
bigc
bigc
421
pitbulls --bighorns--swamplites--reptile radials --these are all oversized by alittle not many true size tires anymore
scott
scott
1,212
1,354
lyman, South Carolina
I would like to get pitbull but to heavy and cost too much.
TandT
TandT
357
21
Newark, Ohio
I know that I'm getting bigger tires and a lift kit!! and a Skid Plate from RED MOUNTAIN PRODUCTS.
bigc
bigc
421
the weight difference is not that much more than other radials and they are no higher than bighorns i have a set of growlers and a set of rockers best tires i have ever ran no better quality atv tires out there
scott
scott
1,212
1,354
Where you get them everywhere I seen they was around $200 + a tire.
bigc
bigc
421
i got mine from discount tire direct i called them and they will come down on price alot i got 8ply growlers for 520.00 to my door
scott
scott
1,212
1,354
$209 for the rocker in 27.5x9x12. $201 for the growler same size. Discount tire direct. You got a deal tho.
scott
scott
1,212
1,354
I'm probably going with the black diamond XTR. I haven't seen a single bad review for these tires. Everyone says they have great lateral control.
scott
scott
1,212
1,354
lol I'm going to do the same.
bigc
bigc
421
scott said:
$209 for the rocker in 27.5x9x12. $201 for the growler same size. Discount tire direct. You got I deal tho.
i got 25.5 didnt want any bigger they run over an inch tall the bigger ones are higher priced
27-11-12 is $160 at Rocky Mountain. I love these tires. I bought the 28" for my pioneer and they perform great.
A2dec61d214cc422197b80f2256b2b5a
204ae86f34c2f17d0b83729d2068faa6
The 28 inch tires measure 28 1/4 inches approximately
Crap, I've heard the 30" Evos only measure 28.5". I want the 28" height.
May have to get the 30" Evos even though they're only 28.5 to get what height I want.
It'd sound "cooler" anyway
I don't understand why the 30" tires would only be 1/4" taller than my 28" tires. BTW, I measured these unloaded. I jacked up the pioneer and measured the back tire with 7 psi. The person that told you the 30" tire was only 28.5" May have measured with the weight of the vehicle or more. Maybe that's what you want, at least I let you know how i measured and the pressure.
Let's ride at Top trails sometime soon and you can test drive my ride and see if you like the tires.
Joe
