farmtimpioneer
Wise Men Still Seek "Him"
OK, I have a Question about True battery isolator, I installed aux. battery and isolator back early 2018 seems to work as intended and I have not had a chance to confirm this or test it but I thought someone may know the answer, I know that when main battery is charged up to peak voltage by charging system or battery charger at that point blue led indicator light comes on and opens circuit to aux. battery and then aux. battery at that point is being charged as well as main battery which is fine if you are charging battery with charger during off time in the shop or whatever, the main battery charges then the aux. battery charges but if you are using vehicle and main battery is constantly in a discharge to where the isolator never opens circuit and you are drawing from aux. battery with accessories than You could get in a situation where the aux. battery would go dead because isolator circuit did not open to charge system, is that correct or am i just full of crap and don't understand exactly how it works, I thought if that is the case than should I put in an override to bypass isolator or manually open circuit for periodic charging,,,,, Thank You,,,,,,
