Good evening all, if anyone can chime in I would appreciate it. I have the true dual voltmeter isolator system everything works except for the voltmeter. Here we go:
I have the key acc power running to the stinger which feeds my fuse panel, I have a switch and usb and lights connected and they all work fine. So the panel works and is getting power. I took the relay which came with the isolator kit for dual battery wires the red to the fuse panel. Wired the black ground wire from the relay to the ground of the fuse panel. I have the dark green wire connected the the back of the voltmeter gold or negative connector. The light blue and green are attached to the silver ones- and the same wires are on the isolator blue on one green on the other. Turn on the bike nothing happens all other acc work great. When I ground it(bike on or off)the voltmeter comes on so it can illuminate. Can there be to Many grounds connected? Is that even a thing? The 2020 bike comes with an extra ground I attached that wire directly to the 2nd battery(don’t think it matters, but at my wits end with this right about now lol) thanks to any and all that can give me some electrical wisdom- I need it
Cheers
Cheers
