P1000 turn the useless cup holders in to defrost ducts
mmorgan
mmorgan
11
34
washington state
Just wanted to share my experience. i just completed installing the inferno heater. I had used up the space on the dash with toggle switch panel w/ cup holders. When trying to find location for defrost leuver's, i set one in the cup holder by accident. It fit perfectly. I popped out the cup holder cut a 2 1/4" hole in the bottom using the current hole as a pilot hole. ran the duct up thru it and attached to the vent outlet it sets down perfectly. The outlets swivel 360' and can be used to heat the riders or as defrost. Very clean professional looking set up. I will add pics tonight.
Vikes79
Vikes79
SKOL!
11,709
113,606
South Dakota
  2. Talon X4 LV
Most like me just cut in bigger holes for holding our drinkin cups ( coffee etc).
heater ducts work, just make sure they don’t run anywhere close to the front drive shaft if your heater box is under the seat like mine.
it’s a mess you don’t want to deal with....
Gabbas
Gabbas
280
701
Humboldt, Iowa
Really debating the inferno heater. Seems to be about the best one. My friend and neighbor actually manufactures them in my small Iowa town. All my friends have them in their SxS's. I just want to know if there is a way to waterproof it under the seat. I hit some good size puddles in the summertime.
Sent from my Pixel 4 using Tapatalk
mmorgan
mmorgan
11
34
washington state
Well I already had bigger cup holders on the dash with the switch panel. So that wasn't necessary for me. as for running the duct up to the front, I used solid abs pipe to navigate the part under the skid plate. then attached duct to that front and back! but thanks for the heads up!
mmorgan
mmorgan
11
34
washington state
What about mounting it in a Battery box ? just a suggestion!
mmorgan
mmorgan
11
34
washington state
I am happy with it so far. One thing i found out with the 3 port vs. the 4 port, the defrost is 21/2" that has to route under the skid plate by the front drive line. i used a solid piece of ABS for that area hooked the duct to it on both sides and continued on up to behind the radiator and installed the "Y" at that point. One thing I will add is, with this method It takes more 2" duct than they send. I had to order a 6' piece to complete the "under seat" connection to the passenger side.
hubbard1986
michigan
How did you route the pipe to driver side cup holder? I used 2 1/2 pipe but hits the steering staft.
mmorgan
mmorgan
11
34
washington state
flex from heater to undercarriage, Start hard pipe up passenger side of drive shaft using elbows ( on both ends) you assemble to exit on the drivers side. Back to flex, go up under battery box, added "Y" from there off to each side and up to bottom of cup holder. What I didn't do that I want to do and think it would help is to wrap the pipes with insulation and tape where you can, before you do final install.
mmorgan
mmorgan
11
34
washington state
Also I just saw that you said you were using 2 1/2" pipe? That's too big I think. The exit hole on the heater is a thin wall 2 1/2 but I cant remember exactly but I used 2" or 2 1/4" If I gave the impression I used 2 1/2" , my apologies..
F
FranklinHonda
10
10
Pennsylvania
Did you ever get to add those pics? I'm thinking about the install myself and would love to have a reference as I will most likely do the same with the louvers. Thanks!
Reactions: ChadD and Smitty335
mmorgan
mmorgan
11
34
washington state
I forgot to photo underneath before I bundled it all up. I am sorry for that. When I take apart to insulate I will take some.
IMG 5973 IMG 5972 IMG 5974 IMG 5975
F
FranklinHonda
10
10
Pennsylvania
Thank you so much. Looking forward to seeing what it looks like when you insulate!
