Joey, I finally pulled the trigger and purchased the Tusk roof. Haven't recieved it yet. I've also got the SATV windshield and would like to know the details on what the bracket you fabbed to solve the interference problem?
Thanks again for the head's up
Ron
Its pretty simple, just a piece of angle that i had. I think it was piece of 1.5" x 3/16", but l am not 100% on that. you could probably use 1/8" and be OK. the angle needed is a little more than 90deg so you need to open up the angle a little.
I just used the mount point for the netting (more on this in a minute) and the slot on the windshield bracket where the clamp attached. Drill some holes and there it is... I originally tapped the upper hole, but dont do it that way. You cant access it after the roof is on w/o removing the windshield.
I will be reworking mine a bit next weekend.
the lower bolt is too small (i think 6mm, cant remember) and it sheared off on my last ride.
All the rocky road riding at the hunting camp is hard on this stuff. I think it just flexed back and forth too many times and then snapped.
For the V2 bracket i will be changing the upper allen head screw (tapped hole in the bracket) to a hex bolt and nylock nut. Also i will try to come up with a way to increase the lower bolt size and still use the tab on the cage. Maybe drill it out and replace with a larger bolt and nut? Not really sure yet. Ill post some updates on it when i finish it.
