P500 Tusk tear wind screen
NitroxDiver
NitroxDiver
488
918
Concord NC
I have one. It’s been on there a couple years. Are you having trouble?
NitroxDiver
NitroxDiver
488
918
Concord NC
I don’t think mine came with instructions but I don’t remember having any problem. If I remember correctly it just Velcro to the top bar and buckled to the sides and bottom but they may have changed the design some in the last couple years .
hallic
hallic
320
1,795
Central MN
Same as mine, no instructions. Start at the top, get the velcro on but not tight. Sides next. I think one spot on each side has to loop around the seat support or something, I dont remember.
Once I had everything more or less in place, snugged up the top first, then went down the sides. Dont think I did the bottom yet, cuz I knew I was gonna have to undo half of it to install snorkel later on.
I can try to snap a pic or 2 tomorrow if ya still stuck.
KYhillbilly
KYhillbilly
548
1,647
Ashland, KY
I take mine off every spring and put back on every fall. Just start with the top fastening to roll bar cross member(can be a pain with roof on and Honda storage bag but doable). Then work your way down. Remove seat back to do the bottom straps.
hallic
hallic
320
1,795
Central MN
Okay, took some quick snaps, havnt had time to get all the mud off yet.
Have honda roof and storage bag installed, so its hard to see the top here, but I have the top of the Tusk window even with the top of the roll bar, more or less:
PXL 20210303 171315692NIGHT
Got this strap hooked up just under the cross bar thingy here:
PXL 20210303 171349812 exported 794 1614792299924
And the bottom I snuck through this support thingy here:
PXL 20210303 171416257 exported 962 1614792287031
CamoP500
89
177
Lake Vermilion
As I recall it helped to pull the back of the seat out before installing. Gave better access to tie down points.
