P500 Uncle Chunga's bolt-on transformation
ChungasRevenge
ChungasRevenge
148
251
The Land of Nod
Picked up a few things for the P5. I don't see doing any radical "mods" that involve reinventing anything already accomplished by the engineers at Honda. My main effort will be the cursory bolt-on additions that are designed to keep Ole' Chunga from getting (too) wet, stroking out or dragging another whitetail out of the "Holler" <<(it's a word).
Stock form (Dealer tossed in the tray and under hood storage)
IMG 2445 IMG 2443 IMG 2449
ChungasRevenge
ChungasRevenge
148
251
The Land of Nod
Found a "Moose" roof @Dennis Kirk good price and free shipping. Test fitting some "closed cell" foam as an isolation damper prior to test fitting the roof. Thought about an aluminum top. Scratched it as a course of action. The Honda OE roof IMHO doesn't quite appeal to me aesthetically enough to spring the extra $$$. So, "Moose" it was..
IMG 2460
IMG 2459 IMG 2459
ChungasRevenge
ChungasRevenge
148
251
The Land of Nod
Test fit the roof. I believe I'll mosey on over to Home Depot and upgrade the mounting hardware (clamps). Moose provides five (5). But, I think an extra mounting point here and there will help...
IMG 2503
Reactions: Eltobgi
ChungasRevenge
ChungasRevenge
148
251
The Land of Nod
Went with an OE bumper. Fair price and sturdy enough for my application. I looked at several different options to include Home fab, but in the end this will suit my needs..
IMG 2504
ChungasRevenge
ChungasRevenge
148
251
The Land of Nod
Found a TUSK rear wind screen for <60$ shipped. Test fit for suitability. Fits perfectly. "Glass" seems good, stitching is good and the mounting hardware is good also. Again, I'll add some closed cell foam to close it up.
IMG 2501 IMG 2502
ChungasRevenge
ChungasRevenge
148
251
The Land of Nod
Ordered an EMP winch mount.
Product is solid, but it did come with a chip in the powder coat, fortunately they did not charge me extra for that. And, it was missing 2 "nuts" for the mounting hardware.
I know it's not rocket surgery to add a winch plate But, there were no directions for mounting this finely tuned piece of kit as well...
No shock to you I'm sure, removing the front "bumperette" is a pre-req to installing the mount..Must have been in the directions.
Called Home Depot to see if they could have somebody run down to the local store and sell me some foam and a couple nuts...Man on the other end said I must already have "nuts" to call on Christmas. People get soooo touchy around the holidays!
IMG 2499 IMG 2500
HUCK
HUCK
1,047
2,315
ARIZONA
Well, I'll have a "look see" when I have it mounted..How is yours holding up?
GREAT ! It still looks new . The foam is a good idea . I added about 4 peaces in strategic places because without it the top vibrated (noise) but with it , it's perfect . Merry Christmas !
Reactions: ChungasRevenge
Good job CR, looks as though you've had some affluence with the misses. What must you have laid beneath the Christmas tree with her name on it. ;)
ChungasRevenge
ChungasRevenge
148
251
The Land of Nod
Changing tactics for the remaining rear dust shield and the Moose rack. I used a rigid closed cell foam for the horizontal braces. For the remainder I used a softer more pliable closed cell foam that bends easily to the contours of the cage. >15$ for two pieces.
IMG 2509 IMG 2510
ChungasRevenge
ChungasRevenge
148
251
The Land of Nod
This gives you a better idea of the two different types of closed cell foam. You can see how pliable it is.
IMG 2506 IMG 2507 IMG 2508
Reactions: Dp5hunter
ChungasRevenge
ChungasRevenge
148
251
The Land of Nod
Just a couple of shots to show pre-zip tie application/post-zip tie. This foam came with an adhesive that made the application very easy to trim around lateral braces.
IMG 2511 IMG 2515 IMG 2516 IMG 2517
ChungasRevenge
ChungasRevenge
148
251
The Land of Nod
These shots show how "snug" the Moose top fits with the extra padding. Its not 100% water/wind proof, but now Ole' Uncle Chunga wont have to wear a wet suit!!!
IMG 25341 IMG 2535
Reactions: rocmar
ChungasRevenge
ChungasRevenge
148
251
The Land of Nod
Shots of the Moose Rack installed (minus the center front mount). I did buy some extra brackets that I plan to install this week..I'm sure it's overkill but,...OK it's overkill:).
I like the fit of the Moose Roof. It is/was easy to install and did not break the bank. I particularly like the low profile look as opposed to some of the other roofs I've seen..
IMG 2531 IMG 2555
ChungasRevenge
ChungasRevenge
148
251
The Land of Nod
I used the "softer" foam for the headrest braces. I noticed that the rear dust/wind screen rubbed against the headrest down tubes. The softer padding should help alleviate some of the wear and tear on the back glass.
IMG 2519 IMG 2520 IMG 2521
ChungasRevenge
ChungasRevenge
148
251
The Land of Nod
Started on the EMP winch mount. With no directions it took me a couple of attempts, a string of unrepeatable expletives and a bruised ego before I mastered the "zen" method of winch plate mounting. With the EMP, I loosely mounted the rear u-bolts using stainless washers and nuts. Then added the front u-bolts, also loosely mounted IOT adjust and align the "Bumperette". Tightened the rear plate then the front mounting hardware. This pic does not show it but, I switched out the factory nuts for stainless. I was out of M-10 lock washers. I was on a roll so I did not make the pilgrimage back out to Lowes for lock washers. I'll add those before I mount the winch.
IMG 2526 IMG 2530 IMG 2537
ChungasRevenge
ChungasRevenge
148
251
The Land of Nod
Winch plate mounted!! I have an "Engo" E10000 winch on my 76 TLC Fj40 (gratuitous shots included). It is a beast. There is a good write up in off-road magazine on the results of a head to head comparison of winches. Engo, IMHO was the surprise of that test. So, In that same vein I'm looking at the Engo E3000 or E4000 for the P5...
IMG 2543 IMG 2549 IMG 2044 IMG 2043
