T
Just an FYI.
The SSL BTB6 sound tube fits perfectly under the hood. No trimming at all. It straps to the radiator support bar. It does not touch the radiator and is not directly above it so heat shouldn't be an issue.
Since I did the reverse mod, I do not use the reverse lever so I ran the power cable through that hole to plug into cigarette lighter. No cutting or drilling at all.
Total cost = $83 from Walmart.
