P500 Under Hood Speaker
Texas_Newfie
115
Katy Texas
Just an FYI.
The SSL BTB6 sound tube fits perfectly under the hood. No trimming at all. It straps to the radiator support bar. It does not touch the radiator and is not directly above it so heat shouldn't be an issue.
Since I did the reverse mod, I do not use the reverse lever so I ran the power cable through that hole to plug into cigarette lighter. No cutting or drilling at all.
Total cost = $83 from Walmart.
Ragnar406
Ragnar406
The Great Bald One
4,446
17,020
Bella Vista, AR
Interesting Idea, How does it sound
jinx
jinx
565
528
I was curious about the sound on these as well. For the price and the fact they use 6.5" speakers had my eye
Texas_Newfie
115
Katy Texas
Not sure how to upload videos. I put 3 videos on FB though (3 genres of music).
Check out the post on "Honda Pioneer 500 Riders" Facebook group.
SXSHP500CO
SXSHP500CO
Pounding - Beaver
232
331
Northglenn Colorado
Nice job! I'm going to look into it myself. What's the reverse mod?
Thanks
11,370
84,757
@SXSHP500CO Reverse lever bypass. Worth doing it, just a nut adjustment under hood at lever cable. P500 Reverse Lever Bypass
SXSHP500CO
SXSHP500CO
Pounding - Beaver
232
331
Northglenn Colorado
Ok. You just have to be aware when you're down shifting correct? Won't it throw it into reverse? Thanks for the tip
SXSHP500CO
SXSHP500CO
Pounding - Beaver
232
331
Northglenn Colorado
Sounds like a good idea. Did I you ever find out how it sound Sounds? Are you going to do it to your rig?
Thanks for the info on the reverse lever
Little_g
Little_g
404
660
Parker, AZ
Got mine yesterday and the speakers came busted. Good thing amazon is good about returns and getting another one out to ya. I also found out my 12v port isn’t working. Gonna check the fuse when I get home from work. Hope this thing works good because I want music this year.
Reactions: SXSHP500CO
Texas_Newfie
115
Katy Texas
After the first ride I found it did sound a little muffled. Pick up some 1.5" and 2" speaker grills (~$5 amazon). Made a world of difference. Other than the one smack dab in the center of the dash, the other 3 are completely out of sight.
I also wired it in to the factory accessory harness under the hood instead of using the 12v plug.
Reactions: Gassygordo
