P1000 Uneven tire ware
G
Gunterpete
Ontario Canada
Hi there.
Passenger front tire is wearing out more on the inside.
Al others are fine.
Is this simple enough for one to handle or do i take it to the dealer.
I have the tools.
Need to know what needs to be adjusted.
Pictures will be appreciated.
Thank you in advance.
208,725
Hi there.
Al others are fine.
I have the tools.
You have an alinement issue. It takes a 14 & 17 mm wrench and a tape measure to set toe in.
SaltwaterSlick
224
946
Southeast Texas
There are some very good youtube videos from guys on this site... just search youtube for Honda Pioneer toe in adjustment or alignment... There are several ways to set up the measurement procedure. Watch 2 or 3 and pick one that best helps you and how you want to do it... I chose the string alignment method. Found it to be very easy and only took about 5 minutes to do the adjustment... now I spent probably 45 minutes setting up the string box so it was true and square... Next time I do it, I will probably be able to do it in less than 10 minutes total now that I've figured it out... It's an easy job and if you're mechanically inclined certainly nothing that the dealer would be necessary for.
Good luck!
5,406
24,778
My trailer is just a bit wider than the buggy. I pull on the trailer rubbing the driver's side tire litely (because I can see it) and measure off the passenger side trailer rail. I confirmed that the rails were parallel first.
115,302
No i found another threat that has pictures and explaines how to do it,
1660744982180
