P1000 utv 801
markc
58
69
eastern kentucky
I like the design but it came out way after I bought my Honda windshield and I would check with them but I think it is only compatible with a MANUAL wiper.
I called them they told me it could work with a electric wiper.Just had to drill another hole but im ok with the manuel one
Reactions: Lady01 and sharp
Plongson
Plongson
271
1,027
Southern Utah
Looking at that site, their windshield only tips out at the bottom. From my experience, the flip up is a much better design. Generally, you want the windshield either all the way up of all the way down...and if you are in dusty conditions, that thing will be a dust monster.
markc
58
69
eastern kentucky
I had a ryfab with same design on a teryx.it was great half open let plenty air in very few times did I open it all the way out really works better the honda hard coat all ways blew air right in my eyes.ryfab doesn't make one for the pioneer I like this because it has dual zone climate control lol.really it put a lot more air in than you would thank I keep the back window on all year no dust
Reactions: Lady01
markc
58
69
eastern kentucky
I talked to the owner of the company. he said all I had to do to put a electric wiper was to drill another hole and it would mount up
Joseph16p3
15
11
Pennsylvania
47B9B9CD 0DB9 4FC0 A3E4 676475B381A9
Just installed my new Utv801 glass windshield. Seems to be of good quality and the owner Fred was good to deal with. Took me about 45 minutes to install myself. The only thing is I wouldn’t suggest the manual wiper that Utv801 sells with windshield very low quality. Hopefully it works as intended but doesn’t look like it will last long
Reactions: Lady01
markc
58
69
eastern kentucky
love my window from them. Fred a super guy and the wipers will do a ok job for what it is
Reactions: Lady01
RedFred1
RedFred1
301
619
North Carolina
Looks good and you got the right color! And just so you know... all Freds are great to deal with!
FredD
Reactions: Lady01 and Joker 02
golden
golden
46
78
Saratoga Springs
Thank you all for the kind words. We are in the process of developing a cover for your windshield while towing or on those frosted mornings to keep the frost off. Looking for your thoughts. Thank you again Fred Mower
IMG 0963
Reactions: Lady01 and Dezrik
Fastbuck101
Fastbuck101
53
84
New Mexico
I was looking at these too, seems like a good design. All the benefits of a glass shield and still can let some air in. I bought a 700 last year, and as I figured, really wanted the 1000. Sooo. Y'all know what I did. Question: The electric wiper for the 700 is quite a bit cheaper than the one for the 1000. Is there a difference, or is Honda just marking it up cause they can? I want to reuse my old one, if possible. I know I'll have to drill another hole, no biggie.
Reactions: Lady01
RockRain
RockRain
48
101
UT
I have that same windshield. I installed dual electric wipers. I chopped my top approximately 4 inches and I was able to cut the top frame down and still remount the electric motors. I will say that it is good quality and the vents work really good, however the dust that it creates in the cab and the heat during the summer is cause for it to be removed during the hotter months.
20181027 174308
Fastbuck101
Fastbuck101
53
84
New Mexico
I have that same windshield. I installed dual electric wipers. I chopped my top approximately 4 inches and I was able to cut the top frame down and still remount the electric motors. I will say that it is good quality and the vents work really good, however the dust that it creates in the cab and the heat during the summer is cause for it to be removed during the hotter months.View attachment 112041
I put in the fabric mid panel, hopefully that will cut down on the dust. Nice looking wiper setup you have, were did you source them?
Reactions: Lady01
RockRain
RockRain
48
101
UT
Pacific powertrain.
All you need to do is run 2 separate relays, 1 for each motor but trigger off the same switch. That way they park when you shut them off because they will get out of synch. Way cheaper then a single Honda wiper system. I made a pattern with 1/4 inch board made the size of the windshield and drilled holes to mount the motors so I could get the sweep to happen in the right place. Arms are adjustable in length to dial it in. I think it was 120 degree is what I set the motors to, as they are adjustable too.
Screenshot 20190303 101100
Reactions: Lady01
Fastbuck101
Fastbuck101
53
84
New Mexico
Pacific powertrain.
Thanks for the info! 1 more accessory to add, does it ever end??
Reactions: Lady01
RockRain
RockRain
48
101
UT
No problem! And no it doesn't seem to. Let me know if you end up getting them and I can make some measurements to get you close to where the holes need to be.
Reactions: Lady01
Fastbuck101
Fastbuck101
53
84
New Mexico
Thanks, I appreciate that. Just checked their website, and they're out of stock on the motors right now. Oh well, got a new winch bumper coming this week. That put a hole in the slush fund.......
Reactions: Lady01
RockRain
RockRain
48
101
UT
Just checked to see if I could source it from somewhere else. Here you go for future reference... It is the 1.5 inch long shaft FYI
Screenshot 20190303 192900
Reactions: Lady01
T
TrailBlazer1000
16
Freeland, MI
It looks like you have a OEM hard top on your machine. How was the fit with your UTV 801 windshield? I currently have that windshield and I am looking at getting the OEM hard top just wanted to know how it fit. Any gaps on the top corners? Did the roof lay flat on the roll bars with the windshield brackets? Thanks in advance.
Reactions: Lady01
