valve specs
bfair
bfair
56
Does any one have the info on setting the valves? I have had many air cooled VW's and spent a lot of time adjusting the valves. I plan on doing it my self. Thanks
bigc
bigc
432
127
the valve lash is on a sticker above the right front wheel
43,293
Now that we have specs, does anyone have the procedure? Scanned FSM pages?
Done it a million times on my old Foreman, but a quick glance at one at a dealer and i didn't spot the usual "plugs" for timing marks and engine rotation. Didn't get much of a look though...
Remember to use feeler gauges on BOTH valves if the rocker arms are forked.
bfair
bfair
56
Thanks everyone for the quick replies. It would be nice to have the procedure also. I guess while I am at it would be nice to have someone do it for me. (LOL)
67,231
How about.. after you done using yours as a test dummy you can do mine.. lol.
Hang tight. I'll snap the pics.
bfair
bfair
56
OK. What does it run for a service manual?
67,231
Found these online :mrgreen:
bfair
bfair
56
Wow you guys are faster than the drive thru at McDonalds. THANKS!!!
43,293
I didn't want to mention names...but i was actually talking to you when i mentioned scans!! ;)
Thanks!!
Looks like i just missed the plugs.
bigc
bigc
432
127
do these have 2 valves or 4 ?
67,231
It has 4. There is another set on the other side of the spark plug.
I have noticed the service manual is kinda brief on a few things. Its almost like they were in a hurry with it.
bigc
bigc
432
127
ok it says remove 4 rocker cover bolts and there is only 2 in the cover shown in the picture i guess i should check my valves i have 355 miles on it
43,293
2 bolts, 2 rocker covers = 4 bolts.
Yes, first service is due at 100 miles or 20 hours. Do it now, before you go to bed!
bigc
bigc
432
127
i done the first service at 100 miles but i didnt adjust the valves
bfair
bfair
56
Maybe I am dumb! Which is intake and which is exhaust? I guess you could rotate till one is loose and one is not. I guess the loose one would be the intake.
67,231
The 2 on the intake side are both intake, the 2 on the exhaust pipe side are the exhaust.
The ones shown in the pictures are both exhaust, you can see the muffler pipe cover.
My issue is always finding Top Dead Center on the compression stroke and getting the (T) mark to stay in the window. It always wants to go past.
