P1000 Vent Lines
nitzo
nitzo
521
1,105
East Coast, Florida
When you are extending the vent lines is there a reason why most folks extend all the lines up to the top or wherever higher. I'm wondering why all the lines, fuel tank, sub trans, rear dif, flux can't all be run to t's down low then run just one 1/4" line up. To me it seems this would be an easier, cleaner way? Unless there is some mechanical reason why not to do it.
farmtimpioneer
farmtimpioneer
Wise Men Still Seek "Him"
549
2,079
Brookville Ohio
You do not want to restrict the vacuum flow in anyway, temperature differences in the different components may draw vacuum or relieve pressure at different times, You may get in a situation where You are actually drawing vacuum or putting positive pressure on another component, to be on the safe side I would run them separately, the most important would be front and rear differential, sub transmission and fuel tank,,,,
TripleB
TripleB
15,241
136,093
Caryville, Tennessee
Honestly, I'd just get the kit from @Bayouownbeer and be done with it. Easy, clean, and simple, just like how I like my women.
This kit is the easiest way to go. Yes u can save some money by piecing together your on kit but I like a couple of clicks and it shows up on my doorstep. Plus he has some pretty easy to follow instructions with pictures.
Vikes79
Vikes79
SKOL!
11,709
113,610
South Dakota
  2. Talon X4 LV
I’m taking the same advice. Just placed my order. Going to do it when I install my skid plates.
Bayouownbeer
Bayouownbeer
797
1,119
Chauvin LA
nitzo
nitzo
521
1,105
East Coast, Florida
I got everything together to do the work this weekend but am still unsure about a single line for every vent. Do most ya'll feel I should run separate lines?
Ultrasonic1
Ultrasonic1
206
766
Nomadic
I thought about this also. I notice on a full tank of fuel, and lots of rocking around, I’ll sometimes get some fuel pushed up in the vent line. It’s very little, and usually returns to the tank quickly. It may be cheap insurance to at least keep the fuel tank vent separate from the others.
Reactions: nitzo and Isaiah
JenElio
JenElio
73,309
667,075
Loxahatchee, florida
Yes,
different components run different temps causing either draw/relief at different times.
My 2 ¢
208,726
Here are links to vent kits for anyone needing one.
Vent extension kit without filters recommended for 5 seater. Filters not needed your preference. Simple hour install. Great piece of mind knowing your covered.
"The Original”Honda Pioneer 1000/700 Vent Extension Kit. Honda Talon Compatible. | eBay
With filters recommended for 3 seaters unless you drill holes.
Your Vent Kit arrived a day early, opened it up and checked it out, very nice! I appreciate how you bagged each vent line and labeled them separately, this is going to be nice! What's the easiest way to get the left front vent down through the dash area and back under the the floor board to the seat area? Ill go back and read the instructions again, I may have the vent lines confused?
Reactions: Bayouownbeer
TripleB
TripleB
15,241
136,093
Your Vent Kit arrived a day early, opened it up and checked it out, very nice! I appreciate how you bagged each vent line and labeled them, this is going to be nice! What's the easiest way to get the left front vent down through the dash area and back under the the floor board to the seat area? Ill go back and read the instructions again, I may have the vent lines confused?
He has instructions on FACEBOOK. I had to get my wife to screenshot them and send them to me. Really simple. Even @Smitty335 can do it. Lol
TripleB
TripleB
15,241
136,093
You're about 4 years late doing this.
smokebuzz
smokebuzz
24
47
Iowa
Just ordered a kit... was gonna piece it together on my own, but by the time i found everything, probably cost more..
Bayouownbeer
Bayouownbeer
797
1,119
Chauvin LA
Sorry just seen the message did you get it. They don’t go under the floor board. Send me a email for printable copy of instructions [email protected]
Reactions: smokebuzz
John_S
59
114
Tennessee
I've had some trouble trying to order this through your ebay page. Is there an alternate way?
Bayouownbeer
Bayouownbeer
797
1,119
Chauvin LA
yes you can buy direct from
Me and save 10% send me email at [email protected]. Which is also my PayPal
$35 without filters $40 with filters. Sent as friend so no fees. Then send me email with mailing address and email address.
208,726
I like the y's instead of the original t's, good move!
