P1000 Vondy’s B-I-L P1000-5 build
Vondy
Vondy
1,392
8,862
Houston,OH
I’ve been commissioned to build up my brother in laws P1000-5. It’s a 2021 that he brought to Takeover this year. Only 100 miles on it. Looking for must haves to get him started.
He purchased with dealer installed:
- Honda Winch
- Snow plow
- Honda poly windshield (not impressed)
- Light Bar.
Plans so far include:
- Factory UTV 1/2” UHMW skid plate
- SuperATV front offset arms
- Garage Products bushings for above arms
- TYT TH8600 radio (Thanks @elkaholic )
-Tires and wheels. 28”-30”
- EBay upper a-arm reinforcement brackets.
- Spare Tie rods
What other must haves? My experience is with a P500 and Talon, so I’m not as up to speed on the 1000 except what I’ve seen a few individuals in here break!
Any suggestions on Rock Sliders to protect outer floor bars? They have already taken a beating!
101AAE76 61D8 45AB 9B32 C166DA7E8DFA
JenElio
JenElio
64,196
602,412
Loxahatchee, florida
Looks good 👍
I'd run some tubing inside that bottom outer bar to reinforce it. If its not too banged up already. Some other guys have welded a pc of angle steel the entire length also.
Frogtown
Frogtown
195
1,484
Kentucky
I ran the jei rock sliders/tree kickers and my rails were still straight except where one of the brackets got pushed up into it. But better then nothing
ToddACimer
ToddACimer
Pioneer 1005-2
3,558
14,599
Oshkosh, Wi
Any good bolt on options to protect? It’s not too bad yet.
Ruffstuff tube gussets are bolt on, I also used 1" VHB to hold them in place.
1 per side if you do the outer rail, I did the inner and outer rails plus used these under my oil pan crossmembers
IMG 20190529 211106
Full write up and more photos here
Post in thread 'Todd's 2018 Build' P1000 - Todd's 2018 Build
Vondy
Vondy
1,392
8,862
Houston,OH
Awesome. Thanks for the info!
56,707
I'd do the angle on the side bars. You could always drill a few holes and run some carriage bolts through if you didn't want to weld them on. You'd need to drill and tap them on the bottom either way to run the skid plate bolts through. This helps too since you can ditch the self tappers with the steel angle being tapped and use real bolts.
BigOL3
BigOL3
2,994
8,918
Definitely do something about sliders to protect the outer bars BEFORE they get bent. I bent mine REAL bad at Tackett and took a lot to even get them close to being straight before reinforcing with angle iron. I used my skidsteer to apply pressure to straighten them. After that I bolted and weld the angle under the tubing and added simple 'sliders' to the side. I wish I had done that to begin with ...... lol
1626186527424
1626186605081
1626186676483
1626186717244
Ohio4x4
Ohio4x4
I brought the dishwasher
1,494
15,019
- Honda Winch
- Snow plow
- Light Bar.
- Spare Tie rods
2x2 angle iron is what I did. It's cheap and very effective. My rails were picking the door up the were bent so bad. I used clamps to pull it back down to the angle iron and tack welded it as I went. They've taken some good hits since with zero deformation.
Ohio4x4
Ohio4x4
1,494
15,019
I ran the bolts through the skid angle and the tube a some additional strength.
Vondy
Vondy
1,392
8,862
Houston,OH
Finally getting start on this
Factory UTV skid was great quality as always. This is the 3rd one I put on. Went with the metal bars to reinforce and just sandwiched them in between
Had to modify the holes in skid some to attach the plow bracket. Worked out real well
9B548700 771A 4D39 A045 2E852142E36D
5209D72D C667 4CF2 9DEF 39FE6C2B7BF4
077149C7 8E82 4082 A017 677C1D26A8AC
JenElio
JenElio
64,196
602,412
what kind of tubing and size ? i need to do that before mine is crushed
I just did mine after 2 yrs of procrastinating :rolleyes: I used 1.25" black iron pipe. If yours isn't as beat up as my ROPS bars were then it "should" go in easy. I had to persuade mine a bit 😂😂
20220514 214823
20220514 233445
Test - Grid
