Warn Front Bumper with Axon Winch Lighting?
Ddoggy
Ddoggy
25
26
Alaska
Looking for insight as to what the Warn Bumper is set up for LED lighting? I prefer Rigid just because of past longevity and performance, but open to any suggestion. It’s on its way and want to be able to put the thing together in one complete shot. Thanks and will be reviewing previous threads. Kudos to those who put the time into this site👍
Reactions: Hondoman
Hondoman
Hondoman
727
1,697
Texas
I just ordered the warn bumper. Did you find a solution for lighting?
ToddACimer
ToddACimer
Pioneer 1005-2
3,804
16,187
Oshkosh, Wi
I think the Talon Warn bumper has the same 6" slot as the Pioneer. I have a 6" Rough Country light in my Warn bumper
IMG 20200514 203745
Reactions: Hondoman
Hondoman
Hondoman
727
1,697
Texas
You might want to check out my build thread and the posts about my Warn bumper upgrades
I saw what you did to close off the bottom, I'll definitely be doing something similar.
I was on the fence about this bumper, but caught it on amazon for $373.31 so I took a chance.
Reactions: ToddACimer
Ddoggy
Ddoggy
25
26
Alaska
well...yes and no,..the 6” rough country seems to be a popular option...I went with a 6” Black Oak (🇺🇸❤️Vets) dual pattern single row..and yes I think it would have worked well. However, once I received the Warn bumper...I honestly did not like where the light location was...very low...and for as many rocky, ice berg situations I will find myself in...figure it would for sure be the first thing that smashes. I dunno...maybe the skid plate on the bumper is stronger than what I think....but I will most likely be welding in some stiffeners in that area for safe measure...I instead Will (obviously have not installed Bar or finished electrical on winch)mount my small bar in the grill area just below the hood latch rung...I feel like it will cast more usable light when winching there too...to fill the Warn supplied cut out and help keep Debris out...I plan on inserting this amber cover that came with the Black Oak led and putting a rock light behind it...if it smashes oh well..it looked good for a while.. and at least I didn’t loose the Bar 😂🤣😂
A96C429C 4DDB 4CF7 B9AC E357E1A9C45B 8D8DFC41 B431 4000 AD5C E337DFC0E1E6
Reactions: Hondoman
Hondoman
Hondoman
727
1,697
Texas
Thanks.
I have a 20" single row rc black series light bar, but to be honest I didnt use it much. I may just add some cube ditch lights instead....
What size shackles fit in the tabs, 3/4"?
Ddoggy
Ddoggy
25
26
Alaska
Cool cool, I have yet to install the Rigid reflect mirrors..that’s all I plan on for forward lighting..if I was going to do more I would replace the headlights before adding another Bar...planning on small cubes low and to the corners for reverse and a Keyed dome light...prob all I am going to do...1/2” shackles for the tabs 👍
Reactions: Hondoman
