I have a Warn 4000S that I bought back in August and used it once, yesterday and it pulled one vehicle (T-Rex) out and wound it back up, the whole spool, he was out there! Then, I was going to pull another T-Rex stuck in the mud and it pulled slower and slower till it finally stopped after about 10' of pull. I smelled an electronic smell smoke and just stopped. Ended up just using the Honda Pioneer to pull out a Kawasaki T-Rex that was sitting on 4" Portals and 33" tires in 2' of mud. Yes, I have video of it all.
Opened up the hood and I noticed my True UTV-SBI-18 light was out and my power steering was weak. Also my Wet Sounds sub woofer blue light turned red and it went off. I put a jumper cable on and was able to retract the winch synthetic wire back in.
Did the Warn pull too much Amperage/voltage too quickly, or did my Battery Isolator go and I didn't notice it wasn't working? This was in the span of about 15 minutes.
I recently had a lot of steam under the hood when my radiator gulped air and overflowed, could that have killed the battery isolator?
I have the winch 2nd battery (Odyssey PC925) on the charger today to see if the isolator light turns back on when I charge that battery back up. Another note: I never had a problem starting it or the radiator fan turning on and off while riding back in.
