P1000 Water in rear end question
IXInaplesIXI
IXInaplesIXI
123
511
South Florida
So I have taken the Pioneer on three trips, two have had water. The deepest I have gone was about 2 feet. I took my bikes in for the first service and my Pioneer already has water in the rear end. I extended all the vent lines already. After I pick it up from the shop I will check to make sure I didn't mess up the vent lines. But I was wondering has any one had water get in easily in the rear or front ends? I know it will eventually get in but I didn't think it would be this fast.
TripleB
TripleB
21,175
184,110
Caryville, Tennessee
I haven't had any signs of water yet. More than likely you make a bad connection or pulled a connection loose. I was paranoid after I extended my vent lines because I second guess everything thing I do. But all have been good so far. Knock on wood.
IXInaplesIXI
IXInaplesIXI
123
511
South Florida
I hope your right and I find something I missed or something loose.
5,764
26,455
If you don't find something obvious, pressurize it with a few pounds of air pressure and squirt it down with soapy water, the leak should be obvious. DO NOT hit it with 100 pounds of tank pressure. :oops:
IXInaplesIXI
IXInaplesIXI
123
511
South Florida
I will thanks for the idea
Reactions: CID
bigshoe
bigshoe
422
1,427
Umm do u fully trust the service department u took it to. I dropped mine off for a recall and ask them to look at low range, was having problems getting it im sometimes. next day they informed something in sub trans was bad. I informed them it was still under warranty 2 days later I got it back with cable adjusted which I knew was the problem to begin with im just saying some of these places are sketchy at best.
  • Sad
Reactions: CID and TripleB
IXInaplesIXI
IXInaplesIXI
123
511
South Florida
Yea, it’s a local family owned shop. Very trustworthy been here since early 80’s. I know what you mean though, I always try to deal with people I trust.
