I have ordered a P 1000-5. I am curious as to the weight distribution between the front and rear tires. Is it 50/50? 60/40? In other words, is there more weight on the front or rear of the unit?
Rear, not sure on % though. I'd guess 40/60. 2 pioneer 1000-5 on a 20' car hauler will sway, have to turn the rear one backwards.I have ordered a P 1000-5. I am curious as to the weight distribution between the front and rear tires. Is it 50/50? 60/40? In other words, is there more weight on the front or rear of the unit?
that would depend on trailer, and if you can get the desired 15-20% tongue weight.Wanting to know if I should drive the 1000 on forward, or back it onto the trailer.
10% to 15% on bumper pull trailer. 15% to 20% on gooseneck trailerGoogling (well, ok, Bing) 'recommended tongue weight on trailer' 10-15% shows up several times.
recommended tongue weight on trailer - Bing
Intelligent search from Bing makes it easier to quickly find what you’re looking for and rewards you.www.bing.com
I bought a 300# shipping scale for reasonable money and use it to set my tongue weight. I have a class C motorhome with a meager 350 lb. tongue weight rating. Wanting a cushion, I set the Talon at 250 lbs. It tows well down to 200 lbs. so I’m comfortable with those numbers.I have the same question. Feedback and sample pictures are appreciated.
Just got a single axle utility trailer 12ft in length X 73” inside fender to fender. Should the pioneer “engine” sit right above the axle or does it need to be a little past the axle? Towards the tongue. I dont believe running the 1K5 all the way to the rail is a good thing, too much tongue weight imo. Thx guys.
Thanks @CIDI bought a 300# shipping scale for reasonable money and use it to set my tongue weight. I have a class C motorhome with a meager 350 lb. tongue weight rating. Wanting a cushion, I set the Talon at 250 lbs. It tows well down to 200 lbs. so I’m comfortable with those numbers.
Although not a P-1000, they’re quite similar in layout, this is how it sits with 250 lbs. on the tongue of my 14’ - 850 lb. trailer. Trailer alone had 129 lb. TW.
Adding 2 spares and a 54 lb. bed extender only moved it forward a few inches, check the distance between the fender and rear tire - still 250 lb. TW. (The red one was stolen )
