What they said ☝️ ☝️ ☝️ ☝️
And to add some winch information for new guys,
The more wraps you have on the drum, the less pulling power you have.
The less wraps on the winch drum, the more pulling power you have.
Found this to help explain
And/Or use a snatch block.
FYI the below diagram is not totally accurate.
Yes, a snatch block does double the pulling power if attached to the load, BUT, every snatch block added to your pulling system reduces your pulling power by 10% do to the friction of going around the sheave. Add 2 snatch blocks, 3 times the pulling power, but, 10% + 10%, is also a 20% reduction in pulling power.
Now that these fine outstanding gentlemen tried to help you again, can you go back and finish your first post about being "
Stuck in 1st"
What did you find to be the problem? How did you fix it?
Inquiring minds want to know....and it might help someone else with the same problem.
And post some pictures of your ride 👍
Have a good day
