Dirtstiffs-1000
- Nov 3, 2018
- 1,734
- 6,258
- 113
- Ownership
1000-5
anyone know if this tusk roof will work with oem honda poly windshields? i already have 2 and don't want to buy a 3rd windshield.
Ordered enclosure and back panel, expected delivery 3 weeks.Check track adjustment, go through the summer/winter changeover gear list, pull cargo sled from storage. Waiting for more snow so I can function check without turning the machine into a mud magnet. View attachment 235902
Tailgate stiffener.
Simple to install.
High quality, light weight metal sheared for a perfect fit and is texture coated to match the bed.
Now I have both a level tailgate and one that is sturdy enough to sit on. I'd recommend.View attachment 235041
where did you get that swing out tire carrier from? Or did you make it?
Ok thanks! Looks great! I saw one somewhere else on here, same idea but had a shelf in the bottom of it. Pretty slick!Wish I could say I took the time and still had the skills to make it but I didn't.
I bought it from Moses at brickcityfab-az.com
Great guy.
I may have a step by step procedure for manually programming that radio. Other than the FRS freq. all others will need a license. The GMRS will require a less costly (I think $5, no test) but all others will require at least an amateur Technician license.Work in progress.
FRS/GMRS range is great at 3+ miles.
Working on an understanding of the radio and Amateur radio license and capabilities.
Where did you order the brake lines from?Ordered stainless brake lines and SuperATV rear a-arms this week.
Probably Jak's the brake lines, They have a totally different brake pedal feel, no squishy feel, I thought I had air in the new lines, pumped a gallon of recycled brake fluid through the system, nope, just no line budge. I like them, just takes a little getting used to. The fronts seemed a little long to me? While I was at it I replaced brake pads, to my surprise the rear was worn more than the fronts, neither were at there service life but I replaced both front and rear pads.Where did you order thebrake lines from?
