chucksmith0706
295
1,103
Louisiana
100% loving my pioneer now.
67403BD5 60BC 4FED 9343 0C41E81F5CF0 4B66F179 D5E3 4ED8 B6C9 B0E315CCF27E FD96EAFB B7D3 4E10 B223 C78C36AD7576 17461F07 6252 42F2 894F E3F2DACC9277 7D5F7DBB C51A 450D 8EFB C1FB8731AC77
toddvdh
toddvdh
1,121
7,412
Green Bay, WI
On the rear panel: The two outside straps (thin) - did you get yours to fit *outside* of the two roof clamps?
I installed my enclosure this evening. Everything went reasonably fine except for the very last strap on one side of that rear panel. The panel is centered and the strap on one end is fine, but I can't for the life of me get the other one to go around the OEM roof clamp on the other side. And unless I missed something, those Honda roof OEM clams do not move side to side.
mine went on the outside no problem. I had to cut the rear panel a little for my backup light.
the front worked good also even with the exo bars and flip up windshield.
I’ll post some pictures tomorrow when I have good internet connection
Reactions: 05Willys and Scoop
Scoop
Scoop
5,438
21,385
  3. Talon R LV
Thanks, @toddvdh
Reactions: 05Willys
PJon
PJon
800
3,243
Arizona
I put a concrete block below the rear arms on the drivers side because the tire is loosing air and the starting battery is officially dead. And so is my tractor battery....never ends...
I put a quart of Amerseal in each tire. Works great! Bead locks no longer leak. Only problem is that the stuff works too well. When you check air pressures, make sure valve stems are at 5:00 to 7:00 position so the the sealer drains out of the valve stem before you put the pressure gauge on them. Other wise, the stuff will keep the valve stem from sealing.
P1K5Dave
P1K5Dave
2,336
8,718
Petoskey, MI
I may have to check out the Amerseal stuff. I keep getting annoying slow leaks, I think I'm on my 3rd or 4th one this season. Getting tired of pulling wheels and running them up to the tire shop.
chucksmith0706
295
1,103
Louisiana
How do you like your Cfab arms? Trying to decide between Cfab and TTC.
I can’t give a real good feedback on how they preform, as I just installed them. Over all with quality and build of them I like them. I would like the spacers to be little tighter on the fit for control arm pockets. I just used a washer. I would buy these again. Check with @P1K5Dave on TTC arms he purchased.
N
Nvrgiveup
Painted the shift indicators so my old eyes can see them, put the Honda roof and the SuperATV windshield on. Then had to take it out and enjoy this 55° December weather here in Kentucky!
Next up is Seizmik Pursuit side mirrors, Trail Armor UHMW skids, 2nd battery, and a winch. Can’t hide money, I reckon!
2BEFFBF1 871D 4A40 B999 3FB1A5D367C4 C40AF0AB 40B6 4844 8216 00D4A3F07556 392CB74C 85D0 4ACA B442 2553772E9DB3
