WagginTail
WagginTail
1,657
6,075
SC
JMynes
JMynes
553
3,267
Augusta, Maine
Today I ‘finished’ my winch install. Well, no, not finished, but I wired it up to a second battery I had lying around, a Duracell ETX20. It’s sitting sideways in the aux battery tray with all winch wiring connected to it, as well as a battery tender pigtail. This setup is temporary, but it got the winch working.
It’s ugly, wires balled up everywhere. Once I decide what I ultimately want to do for a second battery it will get cleaned up. I’m still leaning toward a large AGM under the seat, because I think I want a heater behind the dash. Pretty sure that heater occupies the aux battery space. I also see an auxiliary fuse panel in my future.
No pictures. Too ugly.
JMynes
JMynes
553
3,267
Augusta, Maine
I did the rear door storage mod today. During the process I let the smoke out of my Milwaukee rotary tool (like a Dremel, only red, and we all know red is the fastest color). I discovered that the oscillating multi tool (also red) is a much better tool for cutting the panel sections out.
bumperm
bumperm
1,931
6,829
Gardnerville, NV
Makita has most of my tool dollars in the lithium battery powered department. For the cut-outs, I prefer to drill the corners with a hole saw, then connect the dots, at least on the longer runs, with an angle grinder with thin cut-off wheel. Yes, it's gonna leave a melted ABS plastic lip, but that comes off quickly with a deburring tool. I also use a Makita oscillating multi tool for the shorter cuts and plunge cuts - that, fitted with a narrow blade, makes short work of rocker switch cut-outs in the panel as well.
When reducing the "thickness" of the door color panels for the push button catches, the oscillating tool works almost like a wood plane and is very controllable.
Cely1932
Cely1932
91
591
83
Loveland, CO
Worked on the Trail Armor skidplate today. I opted to install 6mm rivnuts instead of the self tappers. I made a drill bushing that snuggly fit the holes in the skidplate to ensure accurate location.
20220223 133722
All of the holes that were supposed to align with the factory threads did except for the rear most passenger side. It was off by almost ¼". I re-cut a new counterbore and moved on. I believe others have had problems with this same hole.
20220223 131723
20220223 133317
I also had to trim the front of the skidplate just behind the front tires to avoid rubbing until I get A arms.
20220223 124008
20220223 110758
20220223 120341
20220223 120411
20220223 135232
20220223 135320
20220223 135445
Overall very happy with the skidplate.
Scoop
Scoop
5,438
21,385
  3. Talon R LV
Great job, @Cely1932.
My TA skid plates and A-Arm covers are in the boxes in the pole barn. Going to install those when it warms up a bit here. Brr.
212,826
I sold my T-A A arm guards shortly after installing them, they held way to much debris that would rub the boots, was always cleaning them out trail side and a lot easier to clean those areas after they found a new home.
WagginTail
WagginTail
1,657
6,075
SC
I've always thought the same about a arm guards. I have the Honda aluminum ones. Guess I'll see how they do
Scoop
Scoop
5,438
21,385
  3. Talon R LV
Thanks for the 411. I'll have to keep an eye on things.
So you don't run A-Arm guards at all now?
