Jankyeye
Jankyeye
883
4,196
Tampa, Fl.
Mounted some L track to the tusk roof for decoy/blind carrying. Should be the easiest goose season yet.
B6D68146 BA28 460D 84C8 EF3F4C3417E8 910D0139 6D40 4F2B B37B 136A8519339F E9C3E8FE B4A7 4FD7 9DB6 447C8A40C224
Fatsquatch
Fatsquatch
Approved Member
121,611
1,013,795
Hidden
Bumped around Preston County WV with some friends for a few hours on Sunday!
Drop this pic in the current ROTM contest.
Link…
wolf359
wolf359
64
403
Appalachia
Link…
Done. Thanks for the tip!
Glank
Glank
100
340
Well, I finally did it. Got it stuck. Bad driver decision. I was almost out of the swamp and the trial had one last big rut. Why I didn’t straddle it like to previous 20 ruts, I will never know. Buried the A arms and high centered the front end so the front wheel were off the ground. Luckily the SuperATV winch did its job. And the next person can thank me for filling in the rut.
B2855F42 AE78 482C 889E A757D4725BB9
E36F503B 8C6A 4CD3 BBF2 5EF157E46E9E
63FDD94A 21BC 4366 A008 97436F255908
Dirtstiffs-1000
Dirtstiffs-1000
1,734
6,258
hondasxs.com
Well dang it... I wish I had done this before..
My 2018 LE has never, ever overheated above 2 bars until today. We were out in W Oregon in the timber, 4 passengers, just putting along and my wheeler briefly overheated. Once the fan came on, back to 2 bars.
I ordered Richard's fan override kit and some purple ice when we got home.
Thanks Richard.
mlynch001
mlynch001
193
879
Dardanelle, AR
These intercept part of the air that is passing over the top of the windshield when it is tilted out. We found this little trick accidentally when we were putting our hands up to feel how much air was being moved by the tilt windshield. Your hand would deflect the air down into your face. So I Designed and 3D printed a set of roll bar mounted Air Deflectors to mimic our hands into the air stream along the roof. Before these were added, the air that passed over the top of the windshield simply followed along the roof and dumped out the sides or back. This device "scoops" some of that air and directs it to the driver or passenger into the upper body or face area.. Makes a considerable difference in comfort.
IMG 1990
IMG 1989
IMG 1988
jenk61
jenk61
155
1,183
Southern Illinois
View attachment 345609View attachment 345610View attachment 345611
Neat idea, I was looking at printing something similar for a sun visor. You've got the wheels turning. Did you also print the flat part? My printer will only go about 8 1/2 inches square.
mlynch001
mlynch001
193
879
Dardanelle, AR
I printed all of the parts on an Ender 3 235 x 235 mm bed. Printed in PETG. I was restricted in size by my rear view mirror, but these still work great, in spite of being only about 6" (more or less) square.
Dirtstiffs-1000
Dirtstiffs-1000
1,734
6,258
hondasxs.com
Thanks Richard.
Got the Fan override kit, thanks Richard!
Got all but the switch mounted in place. Works as it should.
For you LE guys, there is another wire connection near the fan connection that looks kinda like where you tie in the override harness... it's from the I4wd valve assembly.
Took a few more minutes in the 100 degree heat to figure that out..
Added 3 ounces of purple ice, just for...
Robobrainiac
Robobrainiac
2,706
9,361
Subtract your weight off if you drove on a scale and didn't get off.
That's why I added 350# springs to the rear Fox shocks.
I weigh about 220.
My wife and I with our cooler, and tool bag/box, with some additional stuffs should put the total weight around 2700.
I just invested in the 250lb front and 300lb rear. Do you think I need to go heavier?
Reactions: Fatsquatch
