Wisco-Tango
Wisco-Tango
72
243
Fisk, Wisconsin
Added an under seat fan to keep the heat out.
It's mounted from the trans housing, and I'm currently using some zip ties to stabilize it
1000009976
I used the tabs on the trans to mount the fan, I just bolted it in place and used a small piece of 1/4" fuel line as a spacer.
1000009971
Still allows easy access to the filler cap for oil changes. I may try to replace the zip ties and make a strap using some metal hanger strapping that's used for ducting, but the zip ties are great as you easily add additional tension to stabilize fan
Scoop
Scoop
5,438
21,385
  3. Talon R LV
Mounted the farm jack to the SATV rear tire carrier and added some snaps to my rear mesh panel.
Also, drained and filled the front and rear diffs (Mobil 1 75W-140 Synthetic).
1698541929886
Also changed the oil, filter and front & rear diff service on the '14 Grizzly 700 EPS. Now all three machines have had fresh oil changes and diff service completed in the last month and a half.
chucksmith0706
295
1,103
Louisiana
Just cleaning her up in all areas. Nothing special. Just wanted to make sure I cleaned under seat and motor area. You are correct wet cement area. Was a good ride though, bike performed so much better this year. Shocks, skids, and Super ATV sliders worked so well.
P
packer58
312
946
N. Cali
Reactions: Remington
chucksmith0706
295
1,103
Louisiana
Hopefully I will end up with one in next couple years for mine SxS ride and sleeping quarters.
P
packer58
312
946
N. Cali
You'll love it, i'm on my second enclosed trailer build and there a fun project. 8.5 X 16 V nose is just about right .....
GovtMule
GovtMule
22,181
189,374
Tennessee
Holy $hit, thank goodness for my enclosed trailer. We hauled a few quads back to Colorado several years ago on an open trailer ........they looked a lot like your machine except for the extra layer of mud we had on everything ..........
Pretty sure that’s just foam from his foam cannon…washing round one. Sorta like this.
IMG 7456
P
packer58
312
946
N. Cali
Got tired of getting my retinas burned out by the morning and evening sun through my windshield, my son in law does some window tinting on the side for friends and family so I had him do the top 6" +/- of my windshield. I'll try to get a pic posted in a bit and will report back. Heading for Nevada thursday to help a pal on his bull hunt so should know if it works or not.
P
packer58
312
946
N. Cali
This is what we thought might be a good level for the tint, we'll see soon enough but may be a little low for my liking ....... The enclosure is Alumalite Armour and it is bad ass with the full tip out windshield. Highly recommend it if you can swing it, and Troy is a super dude ....
IMG 5753
