Seadonist
Seadonist
380
1,117
New Orleans
What pressure are you running your inlaws? I got a set mounted today but haven’t had time to put them on my rig yet.
My pressure gauge only reads down to 20 psi so I keep them inflated to the point that the lugs lay flat from edge to edge, which is probably around the recommended 8 psi.
If you start to get higher in pressure, the edges of the lugs start to raise up off the ground
tdhanses
tdhanses
1,044
3,553
Kansas
Spent the morning troubleshooting the code 12 that has been shutting my P1k5 down frequently. Found the problem in the last 3” of the conector going to the front injector. Problem on the green/black wire going to the PCM ground. Hope the pigtails from the club store get here in time for Friday’s ride. Also replaced the air cleaner element. It’s kind of a PITA to get at, but the system works. The filter itself was filthy but the engine side was clean as can be.
I bought 2 of those when I bought my 1000-5 just to have on hand.
PJon
PJon
800
3,243
Arizona
Sounds like they should equip every 1000-3/5 with some extras along with instructions. Is it only the 1000’s having this problem or do the Talons have the same issue? I haven’t read about other models having the problem.
Dirtstiffs-1000
Dirtstiffs-1000
1,734
6,258
hondasxs.com
Experimenting with 4WDKING rock lights for marker & signal lights.
They might be too bright??
20210519 185431
