Robobrainiac
Robobrainiac
2,691
9,334
Had another hectic day of additions. I will need some good time to go thru my build thread at some point and update it. I feel bad because thru these recent projects I haven't been able take take it slow and get pictures thru the process. I will have to walk back thru it at some point. Everything has been so hectic. I added a hi lift jack, shovel, and axe to the rear on the ROPS. I also added a bungee net to maybe hold some stuff near the roof. I also did the Honda vinyl in the front. I am not very good at it so it didn't turn out perfect but from 10ft away it looks good. The shovel is held up using kolpin mounts, the jack is held using a jeep hi lift mount, and the axe is tucked into the side roof area with a bolt in the hole of the handle to keep it there for now.
IMG 20210716 193000 IMG 20210716 190433 IMG 20210716 190439 IMG 20210716 190445 IMG 20210716 190707 IMG 20210716 190513 IMG 20210716 190649 IMG 20210716 190659
bumperm
bumperm
1,921
6,820
Gardnerville, NV
Center of pic shows a Powerlet style (also called BMW plug) with waterproof cap for both charging battery without need to remove hood, and for powering things like an air compressor etc. This type of plug is very reliable.
20210717 165206
20210717 165949
This location for the dual volt meter (came with True battery charging system) faces driver and nothing to remove to reach the back side for mounting and wiring. To the left and below voltmeter is a small rocker switch to disconnect/connect the wireless winch control receiver. It otherwise would be functional all the time (not key on/off) - some have reported uncommanded operation of their wireless winch receiver, probably due to RFI - so the switch is good insurance to prevent damage.
20210717 165139
From bottom of pic to top: Just above "tool box" is the wireless receiver for winch (most of wiring goes to winch reversing solenoid just above. Next above is True UTV dual battery charging system. Upper left is accessory fuse/wiring box that comes with 1000 SE. I relocated this to above the AUX battery which is secured by quick clamp strap (strap is hot melt glued to compartment sidewalls, there a dense foam pad between battery and fuse box to maintain tension. On the SE, they don't leave you a lot of room to add stuff. Still waiting delivery is a smaller buss/fuse box (the one I had is stock is a bit too big to fit).
20210717 165257
That's it for now, though there'll be more to come.
05Willys
05Willys
529
3,323
I've been laid up. Got surgery for a torn bicep a couple weeks ago. I've been going stir crazy with a pile of parts waiting for me. I could not take it anymore and installed the goodies this week (not easy with a bad wing). First up was the 14" radiator fan overhead for cooling the most important sxs accessory (the one who paid for it), next was the wiring headache. Dual battery set-up, fuse block, ground buss, stinger to run fuse block and switch panel. Needed more room to mount all the electric stuff so I removed the intake cover and installed a hose on it. Lastly was the SATV 6000# black ops winch. Long week of modifications Gimping along but now it's DONE. Took it for a ride today fan worked nicely. Oh ya, don't have a pic right now, but I made a couple of temporary 2" bars to see how much air I would get by tipping the Honda oem glass windshield out. Made a ton of difference. Will post pics when I get the final draft done.
20210718 192720 20210718 192530 20210718 192501 20210718 192429
wolf359
wolf359
64
403
Appalachia
What year is your machine? I have a 21 and did not plan on going back to the Dealer for regular maintenance. But, if there are issues that need to be looked at such as what is on your list, maybe I should take it in before warranty is over.
It's a 2020. Back to the dealer was not in my plan either but after about 200 miles this weekend they seem to have done there job without any issues.
StewB
StewB
767
3,551
I gave mine a hug and a kiss because it's safe in the garage.
Grown men and women across the country are mourning the tragedy in Mexico.
Whole lotta back-ordered Can Am's burned in the warehouse fire.
1626822227241
This image is a little too graphic for my delicate constitution.
JenElio
JenElio
81,897
712,927
Loxahatchee, florida
All that competition with polaris is heating things up........
bumperm
bumperm
1,921
6,820
Gardnerville, NV
Maybe a little peck and a pat or two, that'd be okay. A big wet slobbery kiss is just plain perverted and doesn't belong in polite conversation.
bumper (also known as Mr. Manners) :)
Robobrainiac
Robobrainiac
2,691
9,334
I mounted some led lights on the rear of the ROPS. I haven't wired them yet. I didn't want to screw them so I used hose clamps to hold them on. They seem sturdy where they are at and shouldn't get bumped by any trees.
I also hose clamped my aomais go speakers to the ROPS. They seem like they will stay up there pretty good.
I checked all of my lift bolts to make sure they were tight. I wanted to point out the spacers I have on the front are true 1" and just barely stick out. My aftermarket wheels tho clear the studs just fine.
IMG 20210720 175239 IMG 20210720 175247 IMG 20210720 175608 IMG 20210720 180306 IMG 20210720 180302 IMG 20210720 181222 IMG 20210720 181233
Mudwing
Mudwing
36,959
306,672
The Mud holes
View attachment 284653 View attachment 284654 View attachment 284655 View attachment 284656 View attachment 284657 View attachment 284658 View attachment 284659
Instead of hose clamps you can use the Honda quick clamps for a more factory look. They are relatively inexpensive. 😉
Robobrainiac
Robobrainiac
2,691
9,334
yesterday afternoon i was dicking around in my shop and found a can of black vinyl/plastic spray paint,so i finally got rid of the embarrasing RZR logo on my seats.best mod EVER!!!
I don't know how large of an area you need to cover but you could do an iron on patch
