Are they headed out anytime soon for a new adventure? Maybe should have left them gold, might be hindering their capabilities.Oh and touched up the nerfs as some of the gold was showing through.![]()
Maybe a piece of rubber in the wear spot would take care of the problem.My WE's squeak from time to time and I've just accepted it. I searched for the problem when it first started happening a few yrs ago. Pivot points were good and don't know if the Elka's would be the same but I found what appeared to be the spring rubbing on the body of the shock a little. Took a dab of grease and put it on the wear marks and it stopped, for awhile anyway. I hear it occasionally, mainly when the wife points it out. Anymore I just tell her "yeah I hear it".![]()
Yeah, I’m not even sure I hear it while driving or not. Mostly just noticed it while strapping the machine down to the trailer. I ended up buying the WD40 specialist silicone spray. Didn’t make any difference. I guess it is what it is. Just seems kind of soon since I have under 100 miles on these coil overs. I was disappointed to find zero grease fittings on the A-arms.My WE's squeak from time to time and I've just accepted it. I searched for the problem when it first started happening a few yrs ago. Pivot points were good and don't know if the Elka's would be the same but I found what appeared to be the spring rubbing on the body of the shock a little. Took a dab of grease and put it on the wear marks and it stopped, for awhile anyway. I hear it occasionally, mainly when the wife points it out. Anymore I just tell her "yeah I hear it".![]()
Well, I'm not supposed to say anything about the last adventure of the nerfs, technically considered classified. The wife almost spilled the beans to one of her friends the other night. I was enjoying some pistachios so had to snap my fingers and point at her. She didn't want to have to make me get up.![]()
I used to watch "Murder she Wrote", just saying...She actually took it surprisingly well. Has even been making me homemade powdered donuts every morning for breakfast ever since. They don't taste as good as the Hostess kind but I don't complain, it's the thought that counts.![]()
That setup looks familiar!!!WHEW! damn, my back is sore now. Got everything installed, works so far.
Battery wedged in box with some scrap wood and foam rubber, box is screwed onto support plus a ratchet strap just in case:
I know what every wire does in this mess, I promise:
Switch so I can select which battery to trickle charge:
Main battery has a 100amp breaker, Aux battery has a 300amp breaker, plus fuses under the hood for the 'lectricals.
Have it wired up so the charging relay only connects the batteries when red switch is On, so hopefully near zero chance of discharging main battery accidentally.
Tomorrow I'm going to put the side panels back on, and try to find where I put my dual-voltage meter, and get that installed in the dash.
Jessica Fletcher is one person I would never want to be acquainted with .. Everyone she knew was either murdered, accused of murder or actually a murderer.I used to watch "Murder she Wrote", just saying...
