what did you do with your pioneer today
ToddACimer
ToddACimer
Pioneer 1005-2
3,812
16,232
Oshkosh, Wi
Dropped mine off for another rear diff pinion seal and the clutch update/fix.
Max718
Max718
246
366
Mississippi
Painting my cooler rack
Reactions: Plumber32
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
Got a front tire wearing funny so checked alignment and adjusted slightly. While it was on jack stands I greased front arms and inspected CV boots. SATV arms still just barely take grease. I use an electric gun with plenty of pressure and still only got it to take a small amount. Turned 3100+ miles yesterday.
eastenn
eastenn
220
469
Bristol TN
www.fb.com
after a good 2 days of working on it.. added rock lights, flood lights, driving lights, floor board lighting, made a battery box for 2nd battery and installed the battery switch. Also faced a couple marker lights into the headlight housings.. mix of halogen and led lighting bugs me so I wired it where I can run all the rest of the lights with the halogen bulbs on their own switch.
IMG 2169 IMG 2172 IMG 2174 IMG 2176
ToddACimer
ToddACimer
Pioneer 1005-2
3,812
16,232
Oshkosh, Wi
Adjusted my fox shocks. 3/4" spring preload front and 1" rear (as measured front the top of the thread body to the top of the jam nut). Set the compression damping on soft and noted just over 2" of static sag front and just under 2" in the rear. Switched the compression damping back to firm and parked it for the day. Should be softer than before and hopefully removing 1/4" of preload front and about 3/8" rear will reduce rebound bounce.
N
Nick1997
23
24
Cape Coral fl
View attachment 56258 View attachment 56259 View attachment 56260 View attachment 56261
W
Where did you mount just got my set in and been trying to find a good place to mount the
eastenn
eastenn
220
469
Bristol TN
www.fb.com
W
If you're talking about the rock lights, on the front I made a little tab for them and used double side adhesive to stick it inside the fender. On the rear, I used some coarse thread bolts and screwed them into the plastic part of the bed just rearward of the rear doors.
Reactions: CumminsPusher
21,764
93,366
Brought it home from camp.
Time to make room in the garage for it and start modding it again!
