P500 What is my issue.
A
AM500
29
32
Bayou
B6FE2B38 FDF8 4E97 88AE A99BDE7B7539
The cv boot does not appear to be torn. Not sure where the oil is coming from.
68,424
Its either a pin hole or its cut at/under the band.
Pin hole can be fixed it it's small.
Cut can not.
L
LarryAmboy
906
2,021
Castalian Springs, Tennessee
I’ll bet there is a small hole in the boot. Look at the “wet” pattern and there really isn’t anywhere else it can come from.
906UP
906UP
15,061
143,164
da Yoop
It may not be "torn" but it has a hole in it somewhere.....guaranteed.
A
AM500
29
32
Bayou
I’ll look more closely when I get home. Any recommendations on a place to buy cv boots?
906UP
906UP
15,061
143,164
da Yoop
They aren't very expensive regardless of who you buy them from, I got one for my daughters Kodiak off Amazon for less than $10 shipped.
NTC/TAP Transition Member
11,884
90,603
If a pinhole, whats best to patch with? Would black silicone work after cleaning? Asking in case of future need. Thanks.
906UP
906UP
15,061
143,164
da Yoop
I suppose a good quality silicone might work for a temporary fix if the area was cleaned with a solvent....brake clean or similar...
68,424
Yes. ^^this.
I have had good luck with black silicone several times. Degrease it like mentioned. Skuff it up with something if you can, like a wire brush or file. Degrease it again. Put a dab on it and let it dry the recommended cure time. I've had one last a long time.
alloutdoors
alloutdoors
1,022
2,184
US
  3. Do not currently own
I concur, some silicon or similar product would likely work to some degree, but I would strongly recommend replacing it with a new one.
Reactions: 906UP
11,884
90,603
Kinda like duct tape, workshop jewel. If replacing one side due to wear, maybe do both at same time (like brake shoes) since tools are out? Then a good time to install a locker!
8E4452E8 B307 4E4B A8C0 8D302B2A75ED
Reactions: 906UP and Hondasxs
