What is this wire under hood for? Blue tape wire
chops450
Just got this... Wiring my winch in and I see this wire. Anyone know what it's for? It was taped together with blue tape... It's key hot but not 12v I'm only getting 9 and change from it....
0204201849
Hp1
19
Just got this... Wiring my winch in and I see this wire. Anyone know what it's for? It was taped together with blue tape... It's key hot but not 12v I'm only getting 9 and change from it....View attachment 182186
I believe that is the honda (official) ground connection.
That is where i have my winch and true isolater connected to.
1580861095919175144183549175456
Russ989
Russ989
22,642
147,257
No it's not a ground, it's key hot...
It’s your factory sourced ground.
Hp1
19
Hmm. It was over a year ago for my install. So apologies.
This forum is where i found the answers to that same question. Great people here.
Let me look closer, will reply back if i hsve helpful info.
chops450
Sorry and call me stupid but why does a ground have power?
chops450
My machine is a 2018 if that helps... Thanks in advance.
Russ989
Russ989
22,642
147,257
Because on an Atv/Utv the ground completes the circuit. It’s DC not AC, if you had current on an AC ground it would be a problem. If you start your pioneer and check it, I would bet the reading would jump to 12.4+
fishinnut1986
fishinnut1986
20
NC
Wouldn’t a check from ground to ground still read 0? As in from battery ground to the wire in question?
Russ989
Russ989
22,642
147,257
I would think it should, I’m not sure how he’s getting that reading though.
Russ989
Russ989
22,642
147,257
10/4, I would think it would confirm ground.
<———not an electrician, lol
Me neither and I hope I’m not completely wrong. The way I understand it is it’s just a big loop.
fishinnut1986
fishinnut1986
20
NC
It should only be hot if his other lead is to something hot, that actually would prove the ground to be good. I think we are saying the same thing just in reverse.
Reactions: Russ989
Russ989
Russ989
22,642
147,257
Indeed we are lol.
66,869
Hummm... I will have to check mine to see what it reads.
Anyways, this is a ground. Its connected to the engine ground (or frame ground).
It may light up a test light because... hell I dont really know why. lol.
But many grounds will on this machine will do the same thing.
Russ989
Russ989
22,642
147,257
It is a factory ground on the 2017 and newer 1000's. Mine is an LE and it looked identical to that, right down to the blue tape. It is attached to my 2nd battery and isolater now.
I connected mine to my fuse block but I’ve been thinking about going directly to the winch.
Russ989
Russ989
22,642
147,257
I went out and checked mine and it read zero, what say you @Hondasxs?
