They also have metal jacketed ones. I ended up getting that because the shop didn't have a normal one with the terminals where I wanted in stock and they gave it to me for the same price. I used the Bussmann PDM off eBay with 80 amp relay as the isolator.You have to decide where you are going to put it and the layout of the wires.
Only difference is the positive on the Left vs Right.
There a reason you didn't go with a panel with built in relays?Get this for the fuse box Amazon.com : Blue Sea Systems ST Blade Fuse Block - 12 Circuits with Negative Bus & Cover : Fuse Block With Relay : Sports & Outdoors
I haven't ordered the 2nd battery yet so I can't speak on that.
I ordered the 6 and wish I would've got the 12. I'm already low on room.
This one? Pretty sure it's the same guy making them..They also have metal jacketed ones. I ended up getting that because the shop didn't have a normal one with the terminals where I wanted in stock and they gave it to me for the same price. I used the Bussmann PDM off eBay with 80 amp relay as the isolator.
Aweeee man just ordered the 6 two days agoGet this for the fuse box Amazon.com : Blue Sea Systems ST Blade Fuse Block - 12 Circuits with Negative Bus & Cover : Fuse Block With Relay : Sports & Outdoors
Amazon.com: Universal Waterproof Fuse Relay Box Panel Cooper Bussmann ATV UTV RV Boat 4X4: Industrial & Scientific
Sent from my HTC6525LVW using Tapatalk
Currently I have rock lights and a 42 inch light bar. The only lights I plan on adding is a back light.What kind of lights do you have?
I was contemplating going big for future use to buy the length as around 11" and thought it would be harder to mount that of to the side as well... It'll work. Besides, I can always add moreIt will work for sure. I'm not using two in mine right now but future wise I wish I would've just went 12.
I just put in a circuit breaker. I cut everything off when I'm not using the machine. No need for relays if the circuit is broken. Plus it is quite a bit cheaper.
You use a relay?Currently I have rock lights and a 42 inch light bar. The only lights I plan on adding is a back light.
No relay at all. I just hit my circuit breaker when I'm not using the machine. Zero issues so far...You use a relay?
You have a light bar?No relay at all. I just hit my circuit breaker when I'm not using the machine. Zero issues so far...
What kind of amps are you pulling on that? Did you use a heavier switch? I'm contemplating how I'm going to do my setup. I'm not planning on running much more that would require a relay other than a 50" light bar. I can't decide to go with a regular bussman like you have or one of the built in relay types.Yep 42 inch.
I've got a 20 amp fuse on it. I put in OTRATTW Contura V switches. I considered doing the relay but decided not to. If I were to start blowing fuses I'd add a relay but everything has worked fine so far.What kind of amps are you pulling on that? Did you use a heavier switch? I'm contemplating how I'm going to do my setup. I'm not planning on running much more that would require a relay other than a 50" light bar. I can't decide to go with a regular bussman like you have or one of the built in relay types.
