P1000 What pressure washer are you guys using?
Morpheus
Morpheus
109
362
Minnesota
I recently purchased a MasterForce 2300 PSI pressure washer from Menards. Seems to work really well the three times I have used it. It comes with a foam cannon which is nice and a high pressure nozzle that rotates. It's nice and light. I figure when the MN winter comes in a couple weeks I'll just bring it in the basement to keep it warm. I hope 2300 isn't too much pressure. I'm cautious about how close I get to things and only use the medium tip (Yellow) so far. Seems to work nice.
Masterforce™ 2300 PSI 1.5 GPM 13-Amp Corded Electric Pressure Washer
Model Number: MF3N12300 Menards ® SKU: 2611672
Reactions: rtn001
rtn001
rtn001
317
945
Central Florida
I was using a Troy 2750 psi washer until it went south. Needs a new lower unit. I bought a Ferrex 1850 psi electric powered unit from Aldi's for $99.99. and it works fine. Just remembered to buy a can of pressure washer lubricant and put it in when you store the unit for a long period of time. We believe corrosion is what caused my Troy to go bad. If you read a lot of the reviews they say it was working great until it was put up for the winter and would not work when they got it out in the spring.
KevP700-4
KevP700-4
268
639
Northern MI
2650psi Karcher with Honda 6hp motor from Costco. Very good on gas. 10Yrs. old and never a issue. Fresh plug form time to time and a oil change every other year. Just did a 2500sqft. building with it. Nice part was not to much power and not too little power, was just right fir all the requirements of the job. Use it on vehicles as well.
Reactions: rtn001
