P500 What's with all of the rollovers?
None of these Pioneers are corner slingers, not what they're made for. Removing the sway bar reduces its cornering capabilities too, you feel more roll. If you're looking to slide it around you'd be better off with the lower stock tires, spreading the stance and leaving the swaybar, and it still won't be any good at it.
Agreed if you’re going to be riding fast and taking corners at speed the ASB attatched is better.
Reactions: trigger
106,259
4 rolls in the 500. 3 of which were at the Takeover due to deep ruts and mud holes. Once in Washington trying to make a 3 point turn on a narrow trail. I should've gone for the 5 point turn instead.
P
PNWGuy
My off-roading and trail riding has never been for the sake of off-roading, but as a means to get to an activity. I used my ATV to get to a hunting spot, or to explore a mine, etc.
I used to be a drag racer and speed freak. I grew out of it mostly. So, the only time I encounter obstacles are when they are between me and where I want to go. I don't go out looking for ways to break my machine or roll over.
But, with my new Pioneer, I would like to use it for more trail exploring and recreational riding. Not necessarily looking for obstacles, but riding for the enjoyment.
Glad to see I am not the only one that has not removed the sway bar, and knock on wood, I have not rolled mine either.
By no means, there’s more connected than disconnected.
Yep yep, that’s the way. Got all the rest of that behind you......
P
PNWGuy
Ordered 1" spacers for the rear just to be safe. Hopefully the local Forest Service LEO for my district won't use a tape measure and bust me for being over 50"... He said he wouldn't at his bachelor party last week...
212,741
Weren't those really flops? HA!
Reactions: Mudder and 100Acre
NitroxDiver
NitroxDiver
488
918
Concord NC
I feel there is a big difference between “rolling over” and “tipping over”. With that being said I almost tipped over once in slow motion but it stopped before going all the way and I have never come close to rolling it.
Reactions: Mudder
Russ989
Russ989
22,645
147,291
I’ve never been close to rolling mine over. Mine is actually more stable after getting 26’s (same size on all four). I won’t be disconnecting my sway bar anytime soon.
Mudder
Mudder
NTC/TAP Transition Member
11,883
90,593
Reactions: JCMINIS and BWAF
Alan aka Davinci
Alan aka Davinci
Mr. Meme Master
16,808
183,554
Grand Junction, CO
You are correct NitroxDiver, there is a difference between rolling and tipping but people like to say, "Man, I rolled my P5" rather than "Man I tipped over my P5." and makes for a better story.
KYhillbilly
KYhillbilly
562
1,713
Ashland, KY
That's the thing...I seriously doubt the 500 is less stable than the Kodiak @PNWGuy mentioned, but it feels more spooky since it's much harder to add body English.
exactly on an ATV i would stand completely on the uphill side at times in the P500 you cannot add that "English" and with the roll bar and other weight up high the center of gravity is much higher.
