I have play in the rear wheels wheel bearings . The front wheel bearings are good with no play. I had one of the rear bearings , on the left go bad and honda replaced at 1700 miles. 225 miles later I now have both rear bearings with play in them. They don't have as much play as when the one bearing was replaced , but they both have appox. 1/4 " of movement when lifting up on the tires while jacked up off the ground. I don't know if there is a spec as for allowable movement or if I'm back into the honda warranty waiting room. Everything is stock I ride in all different trails . No water in the dessert. Machine drives good no noise .
