Wheel Help
Holopawtalon
Florida
Hi everyone, first post here, I own 2021 Talon X4 live and I ride in Florida lots of mud, sand, and water. does anyone know of a 15” wheel with no bead lock 6+1 front and 4+3 rear well I guess that’s the offsets I’m suppose to get? Also still broken up on tire size Any help is appreciated...
volkspower
volkspower
32
55
Southern Indiana
I think Raceline makes a couple of their non-beadlocks in 6+1, but only in 14", and they don't offer a 4+3 rear in that same style wheel. You could go with 5+2 15 inchers and use a spacer. Failing that, your only stock offset choices I know about in 15" are beadlocks from System 3 and STI.
Method has a few in 15" with 4+3 and 5+2, but no 6+1.
Reactions: Blownzuki
PaulF
PaulF
1,462
4,813
Careful, Raceline 6+1 are NOT 6+1. They are marketed that way so unsuspecting people will buy them. They are more like 5+2 and some are even 4+3.
As a matter of fact, none of the 6+1 are actually 6+1. The closest is the STI HD9 at 50 mm offset and the System 3 S-B4 at 45 mm offset but those are both beadlocks.
The closest non-beadlock wheel I have found is the System 3 ST-3 at +40 mm offset. These would work fine but will widen you up a little and you will need spacers in the rear.
NEVER go by the X+Y offset, that number is a marketing ploy. Always use the true offset when looking at wheels.
To stay as close to stock width, try to find something as close to +50 mm for the front and +15 mm for the rear if not using spacers.
Or use +50 mm all the way around and 1.5" spacers in the rear.
On the X4, anything larger than 30" will rub in the front. Some rounded tread 31's will clear but the more square tread 31's will rub.
Hometeam
Hometeam
976
4,008
Normal, IL
I run 32" Terra Master tires at 10psi on System 3 wheels with a +38 offset (5+2) with 1.5" spacers in the rear on my X. It has rubbed but maybe 5 times in 500 miles. And when it rubbed it was very light and I was at full lock and my suspension was fully stuffed. Now the terror masters have a little bit more of a rounded profile which corners and handles amazing. I prefer a slightly rounded profile over a square top personally. I personally will not run anything less than the 32-in tires on my trail rig. If I was heading to the sand I have a set of 30-in tires to put on for that. In a "trail" setting you really don't notice much power loss going to 32s. The most noticeable power loss happens after 40 or 50 mph in high.
N
nobeer142
17
35
Chippewa Falls Wisconsin
So if i run the system 3 with a 6+1 and 4+3 beadlock with regulator tires 14x7x30 will i need spacer? I can four rims and tires for $1300.
PaulF
PaulF
1,462
4,813
If you are talking about the SB-4, then that is my wheel setup and it is about 1" narrower in the rear. It will work fine.
I am a little OCD so I installed longer studs and 1/2" spacers on mine to even it out.
N
nobeer141
16
Chippewa falls wisconsin
Here is the system 3 installed along with some other pics of things I have done. Memphis sound bar warn 4500 winch kfi winch plate and rear receiver, mud blaster for rear wheels, jei modified spare tire carrier and rotopax gas can. Hated not being able to get in my storage so had swing like a tail gate or just remove it. Super atv windshield and honda rear window. And stainless.exhaust tip.
20210109 142628
20210109 142612
20210109 142534
20210109 142551
SClever
Galion ,Ohio
Here is the system 3 installed along with some other pics of things I have done. Memphis sound bar warn 4500 winch kfi winch plate and rear receiver, mud blaster for rear wheels, jei modified spare tire carrier and rotopax gas can. Hated not being able to get in my storage so had swing like a tail gate or just remove it. Super atv windshield and honda rear window. And stainless.exhaust tip.View attachment 247993View attachment 247994View attachment 247995View attachment 247996
How do you like your tires and wheels So far? Are those the 6+1’s in the front? I have the same tires sitting here waiting on the same wheels, I ordered the 6+1’s all the way around since I’m already running spacers. It’s nice to be able to rotate tires front to rear to help even out the wear
N
nobeer141
16
6+1 and 4+3. I don't have spacers. I like the look and stance but besides two donuts in the street not many trails up here open and not enough ice for lake riding.
