F
New to the site, I just bought a 2021 Talon X. What does everyone use to jack up their sxs to change wheel out on the trails
I use this jack and it isn't bad for the minimal weight that it is. Front is a little squirrely by the time you use a 2X4 and extend the jack out. I have an R so you can jack it up in the rear at the ball joint. Barely even have to extend it to raise the rear. Jack and collapsible lug wrench stowed away nicely behind diff...I have the Tusk scissor jack kit, it's been reported to be a little shaky, so pay attention when you're using it. Another option is an RV leveling scissor jack - both have the necessary travel to handle the long droop travel of our SxSs. I preferred the Tusk because it has a specific roll bar mount.
Tusk UTV Scissor Jack Kit | Parts & Accessories | Rocky Mountain ATV/MC
Shop for Tools, like Tusk UTV Scissor Jack Kit at Rocky Mountain ATV/MC. We have the best prices on dirt bike, atv and motorcycle parts, apparel and accessories and offer excellent customer service.www.rockymountainatvmc.com
Agreed! And when rock crawling, you can always find a big rock to drive up and lift one corner up enough to change a tire without even the winch or anything else.If I’m somewhere that I can use the winch to get the flat tire off the ground that’s my first choice. Second is a high lift. I had the Tusk scissor jack. It’s junk. Would barely lift the rear and had to use a wrench to turn the screw. Total garbage along with the Tusk tire iron. It looks cool on your machine until you need to use it. My buddies wouldn’t take it for free with the ROPS mount after watching me use it.
Yes, agreed, emergency only. I loved it until I used it, in my experience with it the handle bent trying to crank up one 32” rear tire at the ball joint. Of course it was muddy and raining. Then the tusk mini Tri tire iron sheared off. I went to a high lift, It’s heavy and overkill for a sxs. Would be perfect if aluminum.Agreed! And when rock crawling, you can always find a big rock to drive up and lift one corner up enough to change a tire without even the winch or anything else.
As far as that Tusk jack, I would never attempt to lift anything more than one corner of a machine with it. Luckily, with my R and the High Clearance Arms up front, I can lift just one tire off the ground and the Jack can do that pretty easily.
Trying to lift the entire front or rear from the middle is futile but that is not what I bought the jack for, I have other equipment for that.
You always come up with the most cool/useful ideas. Rock on dude!I use this jack and it isn't bad for the minimal weight that it is. Front is a little squirrely by the time you use a 2X4 and extend the jack out. I have an R so you can jack it up in the rear at the ball joint. Barely even have to extend it to raise the rear. Jack and collapsible lug wrench stowed away nicely behind diff...
Looks dandy on video. I too would like to hear from a real time user....Any opinions or experience with these Tuff Trail Gear JackDaddy jacks? They lift from a modified bolt that replaces the lower shock mount & are locked to the machine once lifted. Seems sturdier than a scissors jack and definitely more lift height as needed, and it seems easier to carry than a HiLift jack. I can see some downfalls such as trouble catching the foot to lift the wheel up, particularly on muddy stuff, but I'm sure that can be overcome easily enough.
