I want to run 10x14 wheels on all 4 corners (more tire choices) so my ? Is what would be the closest backspacing measurement as close to stock as I can get. Don’t want to get much wider cause I ride pretty tight trails
factory width is 63”. Aftermarket wheels 14x7 you need 6+1 front off set and 4+3 rear offset. If you ise a 5+2 offset wheel it will increase your width to 66” front and decrease your rear width to 61”. Hence rear spacers even up your widened front width.
