P1000 Wheel upgrade ?
Mahaffey380
24
11
Union Grove NC
I want to run 10x14 wheels on all 4 corners (more tire choices) so my ? Is what would be the closest backspacing measurement as close to stock as I can get. Don’t want to get much wider cause I ride pretty tight trails
farmtimpioneer
farmtimpioneer
Wise Men Still Seek "Him"
549
2,079
Brookville Ohio
14x7 Rims with 5+2 off set 1" spacer in rear, that is my understanding anyway,,
Reactions: mjn and BigOL3
farmtimpioneer
farmtimpioneer
549
2,079
Brookville Ohio
14x7 rims for 10x14 tires whether they be 27" or 28" would probably need A-Arms to do 30"
Sjc3081
Sjc3081
263
442
Wappinger NY
factory width is 63”. Aftermarket wheels 14x7 you need 6+1 front off set and 4+3 rear offset. If you ise a 5+2 offset wheel it will increase your width to 66” front and decrease your rear width to 61”. Hence rear spacers even up your widened front width.
Reactions: farmtimpioneer
Sjc3081
Sjc3081
263
442
Wappinger NY
Are you really asking that question? Are you an adult ? Do you actually own a P1K?
