P1000 Which 235/75r-15 Tire
BWAF
BWAF
I get paid to pass gas
8,864
42,478
Carthage MO
Going to pull the trigger on new tires Friday .Fedral Mt seems to have heavier side wall and little more open 203acbad4fbadab431bf0e0eace3231a
Thunder Mt have more sidewall thread but fill thinner and not as open .Ride trails ,dirt roads, chip and seal roads most of the time . What do you guys think D144d642e908406a919bcb8ce0e855ac
BWAF
BWAF
8,864
42,478
Carthage MO
@GlockMeister do you know? I think alot of guys in Ar run them are they legal in MO
69,293
Do they watch it that close up there ?
Our dnr are like state troopers, anything they can fine you for. I looked up your laws and they are pretty vauge. But in your state parks it does specify high flotation tires. Which truck tires are not.
BWAF
BWAF
8,864
42,478
Carthage MO
You had better luck than me I can't find anything:(
Reactions: Plumber32
BWAF
BWAF
8,864
42,478
Carthage MO
I've got a tire grooving tool if they can't identify it can they ticket you for it ?
BWAF
BWAF
8,864
42,478
Carthage MO
I found atv's half to have low psi tires but haven't found the utv/mov tire specs yet for MO
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
Going to pull the trigger on new tires Friday .Fedral Mt seems to have heavier side wall and little more open View attachment 70814
Thunder Mt have more sidewall thread but fill thinner and not as open .Ride trails ,dirt roads, chip and seal roads most of the time . What do you guys think View attachment 70815
Those thunder are exactly what I have. They are awesome! I put them on last July and haven't touched them since. I haven't even checked air pressure since. Honest truth. I've ridden them at RRB, and mulberry mountain and everything in between. Over 800 miles on them and not a single problem. The sidewall is plenty tough. I run about 8 psi for a little flex and they go anywhere I want to go. They do have great side bite and climb out of ruts well.
crazychris
crazychris
249
532
redfeild arkansas
bwaf let me know how those work for ya. also if they are legal in Arkansas if they work good I just might have to get some of those.
Reactions: BWAF
