I'm no expert on all the different brands since this is my first, I run Super ATV A arms, Elka shocks and 30 inch tires, no spacers, I'm running stock width front and rear. The Super ATV A arms are not adjustable without removing A arm bolts, but there is info on this site that gives you the measurements, thats get's you real close, my stock shocks springs were weak and the shocks were just plain poor quality so up graded to Elka's, any shock will be a huge improvement, gained some clearance there, gained some more with the 30 inch tires and a better ride, I don't run a lift, I question the lift changing the angle of the shocks. I ride a lot off camber stuff, so I like my set up, just like it is. Hope this helps!Looking at a 3 inch or so Lift and high clearance lower a-arms in the front and rear??? who got what???
Would like so feed back so I only have to do this Ones. Thanks every Body.
On the 2016 I put fox shocks and Satv a arms and 28 the was nice just looking for a little more clearence.I'm no expert on all the different brands since this is my first, I run Super ATV A arms, Elka shocks and 30 inch tires, no spacers, I'm running stock width front and rear. The Super ATV A arms are not adjustable without removing A arm bolts, but there is info on this site that gives you the measurements, thats get's you real close, my stock shocks springs were weak and the shocks were just plain poor quality so up graded to Elka's, any shock will be a huge improvement, gained some clearance there, gained some more with the 30 inch tires and a better ride, I don't run a lift, I question the lift changing the angle of the shocks. I ride a lot off camber stuff, so I like my set up, just like it is. Hope this helps!
You have to install steering stops that limit the turn radius some. Its not bad but is noticeable.My stupid question - why do you lose turning? Tires rubbing or something else?
Careful is my middle name. HA!You have to install steering stops that limit the turn radius some. Its not bad but is noticeable.
Some choose not to install but you risk binding and popping the CV cage at full turn if your not careful.
I put the steering stops on the 2016 Pioneer with the super atv a-arms and they sucked for turning and I called Super atv and they said that I did not need them if I am not going to swamp or mud ride. They said if you turn it lock to lock and it grab something it will pull the axle out of the differential. The CFAB a-arms did not come with them and they said they did not have that problem?
I have cfab also and mostly mud ride. And I've had no axle issues.I put the steering stops on the 2016 Pioneer with the super atv a-arms and they sucked for turning and I called Super atv and they said that I did not need them if I am not going to swamp or mud ride. They said if you turn it lock to lock and it grab something it will pull the axle out of the differential. The CFAB a-arms did not come with them and they said they did not have that problem?
Nice. Is the portals worth the money.
I think they are, I love that the axle geometry is the same and the lower (30%) gearing is perfect for larger tires. As I stated above, I stay in Turf when most around me are in 4x4 lock.Nice. Is the portals worth the money.
Looks killer!
That's pretty cool. Are you liking them with the 30s or are you planning on bigger. Just wondering. I've been thinking of portals and I have the same set up without portals though. And were wondering if I went portals would I want bigger?I think they are, I love that the axle geometry is the same and the lower (30%) gearing is perfect for larger tires. As I stated above, I stay in Turf when most around me are in 4x4 lock.
I'm planning on keeping the 30" tires. My wife uses the Honda during the week at the house for around our horse barn and mail / garbage runs down the driveway. She was afraid I was going sky highThat's pretty cool. Are you liking them with the 30s or are you planning on bigger. Just wondering. I've been thinking of portals and I have the same set up without portals though. And were wondering if I went portals would I want bigger?
