I store mine in a Leonard Building, no electric to it , no battery tender. But I ride mine year around. Never had any cold weather start up problems.Both the 5W-30 and the 0W-30 are JASO MA rated.
I have a boat, two tractors, two SXS’s, ranch truck and toy hauler all on these.I store mine in a Leonard Building, no electric to it , no battery tender. But I ride mine year around. Never had any cold weather start up problems.
Monday morning it was at 30 degrees in WV.I have a boat, two tractors, two SXS’s, ranch truck and toy hauler all on these.
https://www.amazon.com/dp/B004Q86JJ8/?tag=sxsweb24-20
Ok..........that won’t affect the solar powered tender/charge controller.Monday morning it was at 30 degrees in WV.
I just bought a new battery and put it on my tender, but it never reaches the float charge. What could be the problem?I have a boat, two tractors, two SXS’s, ranch truck and toy hauler all on these.
I’m not sure about that. Is it a .75 amp tender?I just bought a new battery and put it on my tender, but it never reaches the float charge. What could be the problem?
Either will work. I’ve installed a 10 position grounding bar on mine that I run everything from.Also, thinking about moving the tender pigtail from the battery to the winch contactor. Should I attach the negative to the negative post or to the frame?
Its 900ma... which I guess is .90 amps?I’m not sure about that. Is it a .75 amp tender?
That’s the electric one I use and mine gets to float. You know you’ve got a good battery and you’ve checked the tenders output with a meter presumably??Its 900ma... which I guess is .90 amps?
My meter's dead, so I'll do that as soon I get it straightened out. I know new batteries can be bad, but it cranks strong and starts within one or two seconds. But as soon as I get a good meter, I'll check battery and tender and go from there. Thanks for your help.That’s the electric one I use and mine gets to float. You know you’ve got a good battery and you’ve checked the tenders output with a meter presumably??
Good luck with that, hope it works out because tenders are great.My meter's dead, so I'll do that as soon I get it straightened out. I know new batteries can be bad, but it cranks strong and starts within one or two seconds. But as soon as I get a good meter, I'll check battery and tender and go from there. Thanks for your help.
Damn it man. You Yankees up there got it hard.It was down to -19F
No they don't there balls don't come down until the first of June! HA!Damn it man. You Yankees up there got it hard.
How about us Canucks? I'm about 125 miles North from where that video was taken!Damn it man. You Yankees up there got it hard.
July?How about us Canucks? I'm about 125 miles North from where that video was taken!
I’m sorry.......How about us Canucks? I'm about 125 miles North from where that video was taken!
And I’m guessing you’d know about that...No they don't there balls don't come down until the first of June! HA!
