P1000 Will OEM Honda/WARN winch install kit work on all years?
MountainHighMoto
16
So I just purchased this NOS winch from a Honda dealer brand new in the box for my 2018 Pioneer 1000-5 deluxe.......
08L71-HL3-A41 Honda Pioneer 4500# Warn Winch​
As you may be aware Honda then sells separate the mount/install kit which includes all the wiring. So I found this one one eBay.........2016 HONDA GENUINE PIONEER 1000 3P 5P EPS DELUXE WINCH MOUNT KIT 08L72-HL4-A04 but it basically states it is 2016 only.
Honda is saying I need this one for 2017-up.......Genuine Honda Pioneer 1000 Winch Mount Kit 08L72-HL4-AK1 which will cost me over twice as much as the one I can get on eBay.
The parts look the same visually, from the pictures. I am assuming that a wire or plug or two may be different as they do have different OEM part #'s. Just curious if anyone can speak to this. Thanks
Reactions: Lady01
212,820
I can tell you the factory side plug they use has not changed.
I can't speak on the actual harness.
OW, now you tells! HA!
116,574
Welcome From Michigan.
what state is Your number in your avitar?
Also, Pics Or It Didnt Happen!
Was also going to say what your looking for, should be the same from 16’-21 hardly anything has changed in that dept in those yrs. If its not the same, return it
V
Vetrob1
Sugarloaf, PA
I received a new HF Apex Badlands 5500 long drum for fathers day. I bought the Warn winch mount and it fits perfectly in my 2022 p1k5 with deluxe front guard bumper
Which one was it? I just bought the same winch.
MountainHighMoto
16
Just a heads up, if anyone else is interested..........seems the big difference between 2016 and all other years was in 2016 you had to run a long ground wire that was a major pain in a**. So apparently in 2017 and up Honda started including the wire to make winch installs easier. So my yet to be proven theory is that a 2016 winch install kit will work and will only come with an extra wire that you will not need, and you can buy this kit for $129 instead of $400! Honda - 08L72-HL4-A04 - Winch Mount | eBay I will try and send an update when I finally get around to doing the install.
V
Vetrob1
Sugarloaf, PA
@MountainHighMoto will this mount work for a 5500 long drum apex badlands winch?
MountainHighMoto
16
I can not say. I got it to mount a WARN 4500. I would just compare photos of the two winches. It has been my experience that winches and their mounting holes are pretty universal.
