Winch on a Pioneer 1000-5
G
GeorgeB
Illinois
Which way should a winch turn when you are pulling the cable/rope in?
If you are standing on the driver's side of the Pioneer and you look at the end of the winch, should it turn clockwise or counter-clockwise, when you winch the cable in?
Reactions: Buggyman
115,707
It's all a preference. Also depends on where the fairlead is located, high or low to the winch so u can figure that out. In the middle well....
I see u just joined. Welcome from Michigan
We like Proof picks of the rig when u join. Preferably do an intro thread about yourself and the rig details, year, miles Etc.
Until then.....Pics Or It Didn't Happen!
Jankyeye
Jankyeye
827
4,004
Tampa, Fl.
Welcome from OH! I have a 6k Viper2 (purchased from the club store) and have the lead coming from the bottom with the factory bumper. Reason is that when the lead came off the top it rubbed the winch cross member as it spooled. Coming from the bottom eliminates this but does make for a slightly sharper angle to the fairlead.
Buggyman
Buggyman
44,433
359,411
ne. ohio
welcome from Ohio
Reactions: Rayger143
Scoop
Scoop
5,140
20,318
  3. Talon R LV
Planetary gear winches are designed to work (pull) in one direction due to how it's internal brake holds. Spooling the line off and back on on the outside of the spool is a bad idea with most winches. You'll be fighting the brake when spooling in, and you lose the brake when holding.
Also, some manufacturers do NOT advise flipping thier winches upside down, period. Check with the winch manufacturer about your specific winch before respooling/reversing wires or mounting upside down.
Screenshot 20221001 080848
Buggyman
Buggyman
44,433
359,411
ne. ohio
my superwinch is mounted upside down ( how it was when I bought buggy used) so the rope comes off the bottom and the manual states not to do that so I called customer service and they say it's ok on a sealed system winch like the terra45. no problems in 6 years. 🤞
Scoop
Scoop
5,140
20,318
  3. Talon R LV
As long as the mfg says it's OK, inverting the winch isn't a problem. The problem is spooling the line off the back on incorrectly if you're fighting the brake while winching and losing the brake when you stop.
