1 - Power and Ground should be direct to the battery, it should NOT be ran through a busbar or anything of such.
2 - 6 gauge is common for most UTV brands 6000lb or less.
3 - I think you are asking for the small wire trigger source. This should be acquired from the ACC circuit. Recommend using the below item to acquire this connection without needing to splice. 18 Guage is fine for this.
Quick and easy KEY ON Accessory power source for your Honda Pioneer. PLUG-N-PLAY No Splicing of wires. No Tapping of wires. 3ft lead easily reaches anywhere under the hood. This kit plugs inline with OEM harness and provides a 12v positive lead. Use this Key-On Accessory wire to run the...
store.hondasxs.com
