P700 Windshield brackets
Tim-1000 XT-R
Tim-1000 XT-R
283
899
Oakdale, MN
I have a Honda windshield and it vibrates a lot in the middle lower section. I noticed mine doesn't have the 2 brackets to hold the lower middle section to the dash. Ibought the machine with the windshield on it. My question is do they sell just those 2 pieces that I circled .
0sr72 hl3 a00 2 piece poly windscreen hard coat 190x190
Alan_Vander
Alan_Vander
1,547
2,751
rosepine,la
I havent seen it yet. As a separate peice but might get lucky on ebay. What windsheild do you have? Its just Y peice of plastic. Might find someone trashing a full windsheild or something that has them spare theyd give you .
tjoreo
tjoreo
1,025
1,975
Southern Idaho
It looks like honda has changed the design of there window and forgot to update the pic. According to the new instructions it doesn't come with brackets. My 2015 had them on it which makes me wonder why they changed it. I did a little looking and did happen to find the brackets from Rockymtn. They are spendy little rascals but they should really help.
1595974112684
tjoreo
tjoreo
1,025
1,975
Southern Idaho
Reactions: Tim-1000 XT-R
tjoreo
tjoreo
1,025
1,975
Southern Idaho
If anything else find someone with a 3d printer should be a quick fix lol.
I sure wish I had my 700 still around or at least the dimensions because I do have a 3d printer that could make them easily.
tjoreo
tjoreo
1,025
1,975
Southern Idaho
It's just sad that they changed them. With the shape of the winshield and dash it would let water run inside the cab and onto my switch panel. I ended up putting some weatherstripping in there to stop the water, but without those brackets it wouldn't have held it. Does the windshield have holes for the brackets?
Tim-1000 XT-R
Tim-1000 XT-R
283
899
Oakdale, MN
I wish I knew someone that worked at a Honda dealer just to get them for a reasonable price. Thank you guys for the help.
Tim-1000 XT-R
Tim-1000 XT-R
283
899
Oakdale, MN
Actually no it doesn't have the holes. If a person goes slow can the windshield be drilled? I did think of the water but, like you say use a little weather stripping and if needed some silicone. It will be better than listening to it whack against the dash when riding off road.
tjoreo
tjoreo
1,025
1,975
Southern Idaho
It should drill pretty easily. I put a couple of light pod brackets and wipers on my 1000-5 windshield and had to drill some holes. I used a step bit to diminish the chance of cracking but I don't think you will have any trouble with even a regular twist drill.
Tim-1000 XT-R
Tim-1000 XT-R
283
899
Oakdale, MN
I was thinking these came 2 in a pack for $20 but my local dealership says I need to buy 2 of these because they come 1 per pack for $20. I think that is a crazy price for 2 of these. Can anyone take a couple of pics of what the look like so I can make my own. Thanks in advance.
