P1000 Wiring a winch rocker switch
Neohio
Neohio
Beast of the East
17,912
86,477
Painesville Ohio
When I turn my key on I would like my 7pin mictuning rocker to light up and winch be able to work
Can you share pictures of the current setup? Will be easier for us to see how it is currently wired, and whether it is a Honda install or DIY.
Neohio
Neohio
Beast of the East
17,912
86,477
Painesville Ohio
Does this help?
Capture32
connect "to accessory 1" to in or out on contactor for winch.
connect "to accessory 2" to opposite of accessory 1.
To battery will come from an ignition switched source.
ground is ground.
Neohio
Neohio
Beast of the East
17,912
86,477
Painesville Ohio
The switch backlighting may not come on when turning on ignition. I believe most are designed so the light comes on when activated.
Which I really don't understand. These are momentary, which means the light is only on when your thumb is covering it. So why bother lighting up while in use.
GlockMeister
GlockMeister
The Bearded Wonder
7,606
35,593
Greenville, Mo
If you wire it the way i did in the diagram on post 14 it will be back lit with the key on.
Reactions: Landman
