P500 Wiring sub harness
K
Kirkl
101
92
E. WA
How do I get the red 12v car in my hand connected to the Honda wiring harness in the picture? It has goofy ends on it.
William
William
1,442
2,887
Flowood MS
Cut the ends off and use an inline connector.
William
William
1,442
2,887
Flowood MS
Green should be hot. Mine was backwards! Don't know if it was the light bar wired wrong or the harness though. Use a volt tester.
K
Kirkl
101
92
E. WA
Thanks everyone. Got it all hooked up and working. And yes white cable is hot lol. Learned it the hard way lol
Reactions: William
The Honda wiring harness that I bought had four color coded leads. Only two of them had green ground wires.
K
Kirkl
101
92
E. WA
That's what mine looked like. I guess you could ground to something else if ya needed to
Yep, I did. I installed a ground bar to run the multiple accessories off of.
Reactions: trigger and Rustell
158,264
I did the same...it has come in handy.View attachment 17322
I ran 4 gauge power and ground wires off of the battery through a bushing and into the bottom of the toolbox...stay dry.
I used a fused power bar (for car stereos) and ground bar mounted in box. All led's and winch run to those. Stereo and GPS go to the harness so they're switched power. Wanted some accessories to have ability to run regardless of ignition. Didn't want too much spaghetti under hood.
Accessories are easily added by running wires into bottom of toolbox. My 2 cents.
